trouble with multiple interrupts
djwallace
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Fri Nov 26, 2004 1:56 pm     Reply with quote
I am currently coding an experiment using a pic16f877 for a psychology professor.
I am using 3 interrupts: timer1 (to act as a millisecond timer), ext (to monitor an external button box), and RDA (to check if there is data from the serial port available).
My problem arises when I added the third interrupt. Up to that point my code would compile with approximately ROM at 48% used, and RAM at 68% used.
As soon as I add the serial interrupt it says there is not enough ram left. If I simply remove the #INT_RDA line from above my serial_isr() the program compiles fine.
am i really out of ram?
darryl
PostPosted: Fri Nov 26, 2004 2:11 pm     Reply with quote
Use the "#device *=16" statement to allow use of all ram in the 16F877.
See this thread for an example:
http://www.ccsinfo.com/forum/viewtopic.php?t=20807
djwallace
PostPosted: Fri Nov 26, 2004 2:15 pm     Reply with quote
Thank you!
that worked instantly Very Happy
darryl
