programmed chip does nothing
buckeyes1997
PostPosted: Sun Nov 21, 2004 10:34 pm     Reply with quote
okay so i programmed a simply program that was supposed to set pinb0 high for 100ms and then take it low for 100ms and i get nothing on the scope. i used the wizard to start the project and defined pin b0 as output but i didnt check the box that said to use pullups on portB. it compiled fine and i know the chip is powered and wired correctly as i have gotten a program to work the lcd a little. the program that works was written and compiled with mplab and not ccs.
it seems like even when i compile the program and put it on the chip it doesnt run. if i dont terminate the program it will go back to the top and run the program over and over nonstop right?
what could be wrong.
matt
Mark
PostPosted: Sun Nov 21, 2004 10:39 pm     Reply with quote
All sorts of things. Try posting the code!
lucky
PostPosted: Mon Nov 22, 2004 7:01 am     Reply with quote
The Compiler will add a Sleep(); to the end of your code. Put your code in a loop:
while(TRUE){
     output_high(PIN_B0);
     output_low(PIN_B0);
Lucky
www.mpic3.com - MPIC3 player project, Forum, Downloads, Online Shop
buckeyes1997
thanks
PostPosted: Mon Nov 22, 2004 9:01 am     Reply with quote
yes that is exactly the code i used minus the while statement. i thought about adding that but didnt get to it yet. my thought was maybe it is working but stops so quick i never see it on the scope.
ill try that and see.
buckeyes1997
i think i need the while statement.
PostPosted: Mon Nov 22, 2004 5:24 pm     Reply with quote
is there a way to strip the sleep statement before writing to the chip???
  #include <ctype.h>
  #include <stdio.h>
  #include <stddef.h>
  #include <stdlib.h>
  #include <string.h>
   output_low(PIN_B0);
Haplo
PostPosted: Mon Nov 22, 2004 5:40 pm     Reply with quote
No. You need the while(1); statement.
PostPosted: Mon Nov 22, 2004 5:45 pm     Reply with quote
You still won't see much. The point of a test program is
to make it obvious that things are working. This is best
done with a loop and longer delays. Examples:
http://www.ccsinfo.com/forum/viewtopic.php?t=19199
Mark
PostPosted: Mon Nov 22, 2004 6:32 pm     Reply with quote
To spell it out for you
    output_low(PIN_B0);
buckeyes1997
thanks
PostPosted: Mon Nov 22, 2004 6:49 pm     Reply with quote
hey guys ill try that. i thought about using the toggle function but wanted to do it explicitly.
what time delay should i use to make it show up on the scope more clearly?? i think i should easily be able to observe the 100ms on the scope shouldnt i?? i will try it and report my findings.
thanks
matt
buckeyes1997
hey it works
PostPosted: Tue Nov 23, 2004 6:57 pm     Reply with quote
hey i was able to verify that the pin toggles on the scope. all i had to do was put the while statement in there to keep it out of sleep. why on earth did they put an invisible sleep command in there.
Mark
PostPosted: Tue Nov 23, 2004 7:33 pm     Reply with quote
So it would run off into space and then start over.
rwyoung
Re: hey it works
PostPosted: Wed Nov 24, 2004 8:52 am     Reply with quote
There is no "operating system" to return to as you would have on a DOS/WINDOWS/UNIX/LINUX box.
Writing C code for a microcontroller is not quite like writing for "big iron" and you are ultimately responsible for providing the microcontroller everything it needs, including how to keep it from falling off the edge of the world when your program ends.
A suggestion, if this is your first time working with a microcontroller, I suggest you try writing a few small, simple programs with MPASM (free from Microchip's web site) and get a feel for that before writing much more C code. You don't have to write a file server or TCP/IP stack in assembly, just blink some leds and maybe try using one of the on-chip perpherials like one of the timers and also debounce a pushbutton switch. Knowing how to do that in assembly will really help you later when you are teasing out a problem in C and need to look at the LST file.
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
