code migration from 16LF73 to 16LF76
Sigma
PostPosted: Wed Nov 24, 2004 1:07 am     Reply with quote
Hi, All,
I have a piece of code to migrate from 16LF73 to 16LF76. Compiler version 3.148. The program is a software rs232 on pin_b0. (Later i try to post a sample code on the forum) The code is working fine on 16LF73, but after i modified #include <16F73.h> to #include <16F76.h> (i think that is the only change in the firmware. because these 2 chips are pin to pin compatible, and only that 16LF76 has a bigger size of program memory) The code does not work as good as run in 16LF73. Sometimes communication would break down.
Anybody familiar with these 2 chips? And know what makes this difference?
regards
Sigma
Sigma
PostPosted: Wed Nov 24, 2004 2:32 am     Reply with quote
Here is the simplified version of the code:
#include    <16F76.h>
#fuses       XT,NOWDT,NOPROTECT,PUT,NOBROWNOUT
//----- Pin assignment ---------------------------------------------------------------------
#define PBUS         PIN_B0         //PBus
#define RLED         PIN_C0         //Red LED
#define GLED         PIN_C1         //Green LED
//----- Command Table ----------------------------------------------------------------------
#define nCMD         15
#define   SYNC         0xB5
#define C1            0xBA
#define C2            0xBB
#define C3            0xBC
#define YA               0xBD
#define ACK             0xBE
char len[nCMD]={0,0,1,2,3,
               3,1,0,1,2,
            2,4,1,0,0,      //C1, C2, C3, YA, ACK
#define NORMAL         0
#byte   INTCON = 0x0B
#bit   INTF = INTCON.1
* Variable Declaration
short   rxOK;
char   buf[20];
char   cmd;
char    sleep_count;
char   temp;
* PBus - Using RS232 (Half duplex) functions
#use rs232(baud=9600, bits=8, xmit=PBUS, rcv=PBUS,float_high)
short kbhit_pbus(void)
   return kbhit();
char getPbusByte()
   char   r=0;
   long   i=0;
   char   j=0;
   while(i<100){
      if(kbhit_pbus()){
         r=getc();
      else{
         [b]//delay_us(1);[/b]
                                                [b]i++;[/b]
   return r;
void pbus_send(char cmd)
   char   c;
   char   i;
   char   temp;
   temp=cmd-0xB0;
   putc(SYNC);
   delay_us(10);
   putc(cmd);
   if (len[temp]>0) {
      for(i=0;i<len[temp];i++) {
         delay_us(10);
         putc(buf[i]);
void pbus_receive() {
   char    rx,i;
   char   temp;
   [color=red]rxOK=FALSE;[/color]
   if(getPbusByte()==SYNC){
      cmd = getPbusByte();
      temp = cmd-0xB0;
      if (len[temp]!=0) {
         for (i=0; i<len[temp]; i++) {
            buf[i]=getPbusByte();
          rxOk=TRUE;
      else rxOK=TRUE;
* General Functions
void blinkRLED(char c)
   char i;
   for (i=0; i<c; i++) {
      output_high(RLED);
      delay_ms(10);
      output_low(RLED);
      if (i<(c-1))delay_ms(50);
void blinkGLED(char c)
   char   i;
      output_high(GLED);
      delay_ms(10);
      output_low(GLED);
* main
main() {
   short   done;
   char   count_to_sleep;
   char   state;
   port_b_pullups(TRUE);                     //Port B weak pullup
   output_low(GLED);                        //Off the green LED
   output_low(RLED);                        //Off the red LED
   ext_int_edge(h_to_l);                     //External interrupt edge from high to low
   enable_interrupts(INT_EXT);                  //PBUS is interrupt to wakeup
   disable_interrupts(GLOBAL);                  //Don't use interrupt
   done=FALSE;
   count_to_sleep=4;
   INTF=0;
   blinkGLED(5);
   while (1) {
      if(INTF){                           //If external interrupt (PIN_B0) flagged
         while(sleep_count<count_to_sleep){
            [b]pbus_receive();[/b]
            if(rxOK){
               sleep_count=0;
               state=cmd;
            switch (state){
            case NORMAL:
            case YA:
               pbus_send(C1);
            case C2:
               pbus_send(C3);
            case ACK:
               blinkGLED(5);
               state=NORMAL;
            sleep_count++;
      }      //end if(INTF)
      sleep_count=0;                  //Reset count before sleep
      count_to_sleep=4;               //Reset count_to_sleep to 4
      port_b_pullups(FALSE);            //Port B weak pullup
      output_low(RLED);               //Off red LED
      output_low(GLED);               //Off green LED
      INTF=0;                        //Clear EXT interrupt flag before sleep
      done=FALSE;
      state=NORMAL;
      input(PBUS);
      sleep();                              //MCU sleep to save power
      #asm
         NOP                                 //After wake-up, this is executed
      #endasm
   } //end while
Thanks.
Sigma
asmallri
PostPosted: Wed Nov 24, 2004 3:04 am     Reply with quote
#use rs232(baud=9600, bits=8, xmit=PBUS, rcv=PBUS,errors,float_high)
rxOK is a global variable that is tested in the main() but is never initialised.
The "errors" and "float_high" are mutually exclusive. errors works only with the hardware uart and float high works only with the software uart.
Have you simplified the code too much? In getPBusByte variable i never changes so the delay_us() is never executed.
You have used delays in the switch statements. If the sw uart is used you may miss characters depending on how the application communicating to the PIC behaves. Similarly if the hw uart is used you may get an additional two characters before an overrun occurs.
I can see two ways of significantly impriving the code. One method is to select the HW UART and use interrupt driven receive logic. This will prevent characters being lost during delay_xx()
Alternatively move the LED flashing to a timer interrupt handler. Setup a periodic interrupt (say every 5ms) and use counters to control the LEDs. For example...
// ..inside the timer interrupt handler
    if (Redcount)
         Redcount--;
         output_high(RLED);
         output_low(RLED);
    if (Greencount)
         Greencount--;
         output_high(GLED);
          output_low(GLED);
To have the RED LED turn on for 50ms then in the mainline set Redcount = 10
Regards, Andrew
Sigma
PostPosted: Wed Nov 24, 2004 3:54 am     Reply with quote
Thanks, Andrew. And i am really sorry i simplified the code too much. I already modified the code. Thanks.
Because i call pbus_receive(); in the main function, rxOK will be re-init again. 'i' is also increased when kbhit() not true until certain count exceeds.
I understand external interrupt can do the job, but using this polling i also achieved 0 error rate using 16LF73. But when the code exported to 76, it malfunctions. Their hardware properties should be quite the same, why there is such a difference? What do you think?
Sigma
asmallri
PostPosted: Wed Nov 24, 2004 4:30 am     Reply with quote
Is the hardware identical - that is the only thing that has changed is the PIC? What is the float_high used for?
Regards, Andrew
