How can I use 16c745
young
PostPosted: Thu Nov 18, 2004 10:07 am     Reply with quote
I want to develope a usb application, and I find out that this 16c745 might be the chip I should use. however, what other items should I buy, like the usb cable, and what is the usb interface part, and how this part connects with 16c745?
Mark
PostPosted: Thu Nov 18, 2004 11:25 am     Reply with quote
Go read this app note. It would be a good reference for you.
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1824&appnote=en012103
young
PostPosted: Thu Nov 18, 2004 12:19 pm     Reply with quote
Thank you very much mark:
I read the application not that you provide. from it, I could find the fireware between microchip and 16c745, but i could not find the firware bewtwwen and 16c745 and usb connector.would you please provide more help about this?
young
PostPosted: Thu Nov 18, 2004 12:34 pm     Reply with quote
The 16c745 pin 15 is D- pin 16 is D+ however, there is only one pin Vusb pin 13, how can i connect the data wire to 16c745
Mark
PostPosted: Thu Nov 18, 2004 1:23 pm     Reply with quote
Check out page 34 of this pdf. It is a schematic of the USB portion of the PICKit.
http://ww1.microchip.com/downloads/en/DeviceDoc/40051D.pdf
Mark
PostPosted: Thu Nov 18, 2004 1:27 pm     Reply with quote
Also check out this press release about the new flash versions of PIC18's with USB
http://ww1.microchip.com/downloads/en/DeviceDoc/PIC+USB%20Release,%20Final,%20Web%20Version.doc
zio_pecos
PostPosted: Sat Nov 20, 2004 1:54 am     Reply with quote
for my application was very useful...
http://www.alanmacek.com/usb/project.html
PostPosted: Mon Nov 22, 2004 8:51 am     Reply with quote
thank you zi0_pecos:
Would you help me find out what DDK should i download, I went to ther website in msdn, http://www.microsoft.com/whdc/devtools/ddk/default.mspx, but I do not know where to download, and which one, it is also look to me that it is not free?
PostPosted: Mon Nov 22, 2004 9:11 am     Reply with quote
www.delphi-gems.com
here you can find the usb component
and some examples very useful
rwyoung
PostPosted: Mon Nov 22, 2004 9:46 am     Reply with quote
You would pick the one associated with the version of Windows you expect to use. Note that the Windows 98 DDK is "retired" and no longer supported by Microsoft. The Windows 2000 DDK is also retired but is still supported.
Only the DDK Suite 3 kit is available. It is available for purchase seperately or as part of a MSDN (Microsoft System Developer's Network) subscription.
In either case, it costs money.
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
alexz
PostPosted: Tue Nov 23, 2004 10:10 am     Reply with quote
Anonymous wrote:
www.delphi-gems.com
where exactly?
I could not find any Sad
Alex
PostPosted: Tue Nov 30, 2004 2:55 pm     Reply with quote
I bought a 16c745 jw which can erease the memory to reprogram it, Do I need special device to erase the old program and use programmer to write in or just use progremmer to write as normal chicps?
rwyoung
PostPosted: Wed Dec 01, 2004 3:09 pm     Reply with quote
The JW package is a windowed ceramic DIP. You need a UV (ultra violet) light chip eraser. Ebay sometimes has nice ones for a few buck. Otherwise Google around for terms like "UV eraser" and "erasing EPROM". Digikey, Mouse, Newark, Allied, Jameco probably have things in their catalogs.
It is possible but not practical to just leave the chip expose to direct sun light to erase but that will take a VERY LONG time. A good erasing unit can get the job done in 20 to 40 minutes.
Rob Young
SherpaDoug
PostPosted: Wed Dec 01, 2004 3:45 pm     Reply with quote
I use a Datarase II from Walling Co.. Is is cheap but does the job in under 15 minutes. There is one on Ebay (3856251543) currently for US$7. Mine was probably under $25 new.
