pcw instruction
zio_pecos
pcw instruction
PostPosted: Wed Nov 17, 2004 2:46 am     Reply with quote
i need to know differences between c and pcw instruction
in terms of
bit lenght
potentiality
do you know a web link or can you tell me something?
thank you
Re: pcw instruction
PostPosted: Wed Nov 17, 2004 3:11 am     Reply with quote
in terms of
bit lenght
potentiality
thank you
PCW, is 'C'. It is in some ways closer to the original K&R definitions than most modern compilers (which support an extended 'set' of syntax and instructions in 'ANSI C'). 99% of the original C instructions are supported. 'Bit length'?. 'C' has no effect on the ability of the processor (CCS have here followed the original K&R defintions, where the definition of an 'integer', is that it should be the 'native' type for the processor). Hence the CCS C, uses int to represent an 8bit value, but then offers a int16, and an int32. 'Potentiality', just about anything that can be written in normal C, can be written into the CCS, but you then have the limitations of the chip itself. For example, 're-entrancy', cannot be supported without some form of variable 'stack', which the chips do not support. Code size, and the number of variables, are dependant on the chip involved. CCS, has some (significant) weaknesses, when complex constructions are used (structures, containing further structures/unions, going to a significant 'depth', seem very unreliable). However these are beyond anything illustrated in the original K&R book. Allmost every example in K&R, can be directly compiled and run, except for a couple using re-entrancy.
Beyond 'C', the CCS compiler adds quite a lot of 'extras', for direct I/O (the #bit, and #byte operators etc.).
PostPosted: Wed Nov 17, 2004 10:46 am     Reply with quote
thank you... Smile
i've posted this question because a friend of mine had found on the net a document that illustrate with high precision a comparing between pcw and C
all that you told me is what i was looking for
thank you
i there is anything else post it!!!!
Very Happy
PostPosted: Wed Nov 17, 2004 11:02 am     Reply with quote
Anonymous wrote:
thank you... Smile
thank you
Very Happy
I think the key here, will be 'ANSI C'. In ANSI C, the default 'integer', is a 16bit type. In the original C, the default varied with the processor, and this is retained in CCS C.
