error in an easy code
curious
PostPosted: Tue Nov 16, 2004 12:47 pm     Reply with quote
Hiii guys....
I compiled den.C file with den1.C
den1.C is clearly included in the den.C.
But I got an error such as "undefined identifier b".
when I put int b=1; in the main . It is OK.
But for this time,
I got "Can not change device type this far into the code"
What should I do?
I use 3.155 ver., MPLAB IDE ver is 6.3.
What is the reason you think?
thanks for help
// The following is the first file (den.C)
#include<16f877.h>
#include"den1.c"
main(){
int a;
a=a+b;
return 0;
// This one is included file (den1.C)
#include<16f877.h>
int b=1;
fonk(){
return b;
John Morley
PostPosted: Tue Nov 16, 2004 12:51 pm     Reply with quote
If you read the error message carefully, I think your problem becomes quite obvious! Apparently the compiler does not like the fact that you have an #include<16f877.h> statement in each module. At least that is how I would interpret the "Cannot change device type this far into the code" error......
John
John Morley
