Memory Mapping
ritchie
Memory Mapping
PostPosted: Mon Nov 15, 2004 10:31 pm     Reply with quote
Question on memory mapping?
I have a structure for PortA... say,
struct {
unsigned int A0:1;
unsigned int A1:1;
unsigned int A7:1;
} PortABits;
#locate PortABits=0xF80
With this structure you can now set/reset bit specific ex. PortABits.A0 = 0.
My convern really is that? Is their another way of doing this without using #locate but still you can use the instruction PortABits.A0 = 0?
Need your comments and information.
Thanx
Haplo
PostPosted: Mon Nov 15, 2004 10:53 pm     Reply with quote
One other way:
#bit A0 = 0xF80.0
Then you can use A0=0.
Mark
PostPosted: Tue Nov 16, 2004 5:42 am     Reply with quote
No matter how you do it, you still have to tell the compiler what register portA is.
Trampas
PostPosted: Tue Nov 16, 2004 6:40 am     Reply with quote
ritchie,
Is your concern the portablitly of the code?
Since the CCS compiler does not have a linker, their is no other way to locate the variable other than the #locate.
What you can do is set up a #if statement which detects which compiler you are using and then place all the locate statements in there. This way your code can still compile and run on multiple compilers.
Trampas
ritchie
PostPosted: Tue Nov 16, 2004 7:15 am     Reply with quote
Yah my concern really is the portability of the code for other PIC compilers coz the #locate and #bit are CCS specific built-in preprocessors.
Similarly the CCS #byte preprocessor-- I never use this coz I have my own definition which is similar to a #byte and it goes this way:
#define PORTA_BASE      0xF80
#define PortA          ((unsigned int *) PORTA_BASE)
or
unsigned int * const PortA = (unsigned int *) PORTA_BASE;
then u can read/write the PortA register by using the instruction below:
*PortA = (unsigned int) value1;
value2 = *PortA;
With the code above this is more portable than using the #byte preprocessor of CCS.
BTW, the assembly listing of uisng the *PortA is similar to the assembly listing of using the #byte.
In relation to the #define I mention above, I came to a point if it is really possible to not using the #bit and #locate preprocessor and still you can manipulate the specific bits of a register.
Any suggestions and comments are welcome.
Thanx
Trampas wrote:
ritchie,
Trampas
[/code]
Mark
PostPosted: Tue Nov 16, 2004 7:19 am     Reply with quote
Put the declarations in a header file. For the C18 compiler, "I" do not have to specify the locations. Switching between the two compilers, I just include a different processor header file.
Haplo
PostPosted: Tue Nov 16, 2004 3:38 pm     Reply with quote
Stay away from #byte and #bit. Use statements like input(PIN_A0) or output_low(PIN_A0). Any other compilers you may want to migrate to later will definitely have similar funtions and changing the code will not be that difficult.
