Fill EEPROM on PIC18F8585
PostPosted: Mon Nov 15, 2004 7:02 am     Reply with quote
Hello every body,
I use the EEPROM of PIC18F8585 as parameter table, I'd like fill a default table for the first run.
Do you know how I can do to fill EEPROM with value at compil step.
I found this solution
#rom ADD_OF_EEPROM = {0x1234}
with ADD_OF_EEPROM = 0x0F0000
what do you think about that? does the address is correct?
Many thank
Thierry
PostPosted: Mon Nov 15, 2004 1:41 pm     Reply with quote
The address of the Data EEPROM is usually given in the Programming
Specification for the PIC.
So go here, to the 18F8585 page:
http://www.microchip.com/stellent/idcplgidcplg?IdcService=SS_GET_PAGE&nodeId=1335&dDocName=en010321
Then download the Programming Specification. Then look for the
section in that document called:
"Embedding Data EEPROM Information In the HEX File".
Then you will find the address.
PostPosted: Wed Nov 17, 2004 8:06 am     Reply with quote
Many thanks Very Happy
Thierry
