Startup troubles
YulL
Startup troubles
PostPosted: Mon Nov 15, 2004 8:02 am     Reply with quote
I have a strange problem with my application : when I turn off the power and turn on again, my program works well sometime and doesn't work the others time... I have debug LED's that light up sometimes (not always) even if my program have a good reset... Crying or Very sad
I send you my source if you want to see...
#include "...header.h"
#include <stdio.h>
#include <lcd.c>
typedef struct
int8 longueur[2];
int8 prim[2];
int8 param[32];
int8 header;
int8 CRC;
int8 SuId;
int8 TxSeq;
int8 RxSeq;
int8 IC;
int8 PF;
} BUSMAIL;
BUSMAIL PIC, CVM;
int8 etat=0, i=0, traitement=0, init=0, linestatus=0;
int8 CVM_Result_CRC;
int8 SABM[5]={0x10,0x00,0x01,0xC0,0xC0};
int16 *CVM_length, *Primitive;
void send_SABM();
void send_control(int8 SuId, int8 RxSeq, int8 PF);
void API_FP_INVOKE_ACCESS_RIGHTS(int8 TxSeq, int8 RxSeq);
void API_FP_CONNECT_REQ(int8 TxSeq, int8 RxSeq);
void CVM_FP_AUDIO_OPEN_REQ(int8 TxSeq, int8 RxSeq);
#int_rda // Cette interruption detecte et gere une trame
void serial_isr()
if (!traitement)
switch (etat)
case 0: // Lecture du Frame Char
if(getc()==0x10) etat=1;
else etat=0;
case 1: // MSByte of Length
CVM.longueur[1]=getc();
etat=2;
case 2: // LSByte of Length & constitution de length (16 bits)
CVM.longueur[0]=getc();
CVM_length=(int16*)CVM.longueur;
etat=3;
case 3: // Header
CVM.header=getc();
etat=4;
if(CVM.header==0xC8) { etat=0; traitement=1; }
case 4: // 1er octet du mail
if(getc()==0xFC) etat=5;
else etat=0;
case 5: // 2eme octet du mail
if(getc()==0x00) etat=6;
else etat=0;
case 6: // LSByte of Primitive
CVM.prim[0]=getc();
etat=7;
case 7: // MSByte of Primitive
CVM.prim[1]=getc();
etat=8; i=0;
case 8: // CRC ou Parametre?? Etudier la longueur Header+Mail
if(*CVM_length-i>5)
CVM.param[i]=getc();
i++;
etat=8;
else if(*CVM_length-i<=5)
CVM.CRC=getc();
traitement=1;
etat=i=0;
if(traitement) // Si on a une trame ŕ traiter...
disable_interrupts(INT_RDA); // interruption interdite dans ce "if"
CVM.IC=((CVM.header)&0x80)>>7; // Info Frame ou Control Frame ?
//////////////////////////////INFO FRAME//////////////////////////////////
if(CVM.IC==0)
CVM_Result_CRC = CVM.header+0xFC+CVM.prim[0]+CVM.prim[1];
for(i=0;i<((*CVM_length)-5);i++)
{ CVM_Result_CRC = CVM_Result_CRC + CVM.param[i] ; }
Primitive=(int16*)CVM.prim;
if((*Primitive==0x2F41)&&(CVM.param[0]==0x82)) linestatus=1;
if(CVM_Result_CRC==CVM.CRC) // Si le CRC est bon
CVM.TxSeq=(CVM.header&0x70)>>4; // Numero de l'info recue
CVM.RxSeq=(CVM.header&0x07); // Ce que le PIC enverra...
PIC.TxSeq=CVM.RxSeq; // Le PIC enverra l'info attendue
if(CVM.TxSeq!=PIC.RxSeq) // Ce n'est pas l'info attendue par le PIC
{ send_control(1,PIC.RxSeq,0); } // REJ = rejet
else // C'est bien l'info attendue
PIC.RxSeq++; // On attend l'info suivante
CVM.PF=(CVM.header&0x08)>>3; // PF ou noPF ?
if(PIC.RxSeq==8) PIC.RxSeq=0; // Rx va de 0 ŕ 7 seulement
if(CVM.PF) { send_control(0,PIC.RxSeq,0); } // on accuse...
/////////////////////////////CONTROL FRAME////////////////////////////////
if(CVM.IC==1)
if (CVM.header==0xC8) { send_SABM(); init=1; } // SABM
CVM.SuId=(CVM.header&0x30)>>4; // RR, REJ ou RNR
CVM.RxSeq=(CVM.header&0x07); // Cependant, tjrs RR
PIC.TxSeq=CVM.RxSeq; // Le PIC enverra ce qu'attend le CVM
traitement=0; // Il n'y a plus rien ŕ traiter, on ressort et on attend
enable_interrupts(INT_RDA);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
set_tris_a (0x00);
set_tris_b (0x01);
set_tris_c (0xBF);
output_low(LED0); // Permet de voir si le PIC est bien alimenté
output_low(LED1);
enable_interrupts(INT_RDA); // Interruption Port Serie
enable_interrupts(GLOBAL); // Enable Global Interrupts
//while(init==0){} // Si le SABM a bien ete recu...
/*// Les mobiles peuvent acceder ŕ la base pour l'abonnement
API_FP_INVOKE_ACCESS_RIGHTS(PIC.TxSeq, PIC.RxSeq);
PIC.TxSeq++;
enable_interrupts(INT_RDA);*/
while(linestatus==0){}
output_high(LED0); // Permet de savoir si le programme n'a pas planté...
// FP answers an incoming call
API_FP_CONNECT_REQ(PIC.TxSeq, PIC.RxSeq);
PIC.TxSeq++; if(PIC.TxSeq==8) PIC.TxSeq=0;
// This command is used to open audio in the FP speakerphone
CVM_FP_AUDIO_OPEN_REQ(PIC.TxSeq, PIC.RxSeq);
while(1) {}
and the header.c file :
#include <16F873A.h>
#device adc=8
#use delay(clock=7372800) //7372800
/*#use fixed_io(a_outputs=PIN_A0, PIN_A1)
#use fixed_io(b_outputs=PIN_B7, PIN_B6, PIN_B5, PIN_B4, PIN_B3, PIN_B2, PIN_B1)
#use fixed_io(c_outputs=PIN_C6)*/
#fuses HS, NOWDT, NOPROTECT, NOLVP, NOBROWNOUT, NOPUT
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#define LED0 PIN_A0
#define LED1 PIN_A1
Thanks by advance for your interest Smile
drh
PostPosted: Mon Nov 15, 2004 8:20 am     Reply with quote
Enable the power up timer and brownout detect.
David
YulL
PostPosted: Mon Nov 15, 2004 9:05 am     Reply with quote
Maybe but the problem is that I use the PIC16LF873A and my application run at 3.6V so Brown Out is not the right solution... Embarassed
PostPosted: Mon Nov 15, 2004 10:05 am     Reply with quote
I'm afraid that the problem requires a 'brownout' solution. The odds are that whatever you have as a reset circuit on MCLR, is not properly resetting the chip, if the supply is not off for a reasonable time. Remember that there is nothing to stop you implementing your own 'brownout' external to the chip. Several manufacturers (Maxim for example), do power supply supervsory IC's, that will trigger a reset. Alternatively, it is possible that using the watchdog, could allow you to force a reset if the main code is not running.
YulL
PostPosted: Mon Nov 15, 2004 10:19 am     Reply with quote
Yes we've decided to use a MC330164D5 or LM8364 (National). I think it should explain why my program is not very stable when I disable BrownOut... Crying or Very sad
Thanks for your support Rolling Eyes
YulL
PostPosted: Mon Nov 15, 2004 10:41 am     Reply with quote
...and the WDTimer is not appropriate because I'm listening and driver and a component that send a start frame after being powered up... Rolling Eyes
