Maximum Transfer rate?
Einly
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger ICQ Number
PostPosted: Mon Nov 15, 2004 3:15 am     Reply with quote
Dear all,
I wish to send data from pic to a computer through RS232. Each second, I would like to send 20kBytes of data. May I know how can this transfer rate be achieved? If not, what is the maximum transfer rate be achieved and how to achieve it? Either hardware/ software?
Einly
PostPosted: Mon Nov 15, 2004 4:05 am     Reply with quote
20kBytes per second equals 200kbits per second including start- and stop-bits.
Depending on the chosen clock speed the hardware UART of the PIC-series goes up to 2500kbaud at 40MHz, so your data throughput is possible.
There are some limitations though:
- At these high baudrates the line length for RS-232 is limited to about a meter.
- The mismatch between the UART baudrate settings and the required baudrate has a maximum allowed error of 4%. This may require less common clock frequencies.
For these amounts of data I would recommend looking into USB which is better equiped to handle these throughputs. Also consider many of the newer laptops are supplied without RS-232 connector.
asmallri
PostPosted: Mon Nov 15, 2004 7:56 am     Reply with quote
Another alternative is to use an ethernet interface running TCP or UDP. Application development is easier and far more portable across operating systems, platforms, and applications than USB.
Regards, Andrew
