16F877 to 18F425 migration problems
Henk
PostPosted: Thu Nov 11, 2004 6:23 am     Reply with quote
Hi.
I have run out of program space on a pic16F877 , so have loaded the code into a pic18f425, same hardware, including 4mhz xtal.
The code compiled and loaded (using MPLAB ICD 2) with no errors, but doesn't execute. I have checked the clock with a scope, and even tried setting to HS (this still OK for 18F425 at 4mhz). Only activity on the chip is the clock inputs, no other pins change state. Any ideas?
Mark
PostPosted: Thu Nov 11, 2004 7:28 am     Reply with quote
This is with the PCH compiler, right?
No, should be XT
Write a small "test" program with the new chip and see if it does anything.
Also make sure that you have NOLVP in the fuses. I believe the LVP pin changed on the 18's and this will cause you problems if you don't disable it.
treitmey
PostPosted: Thu Nov 11, 2004 8:35 am     Reply with quote
These are totaly different processors,.. Did you change the references to port locations and OTHER processor specific items?
ie: port A on 16F877A = 0x005
port A on 18F452 = 0xF80
There are alot of things that might need to be changed.
Did you change these??
Mark
PostPosted: Thu Nov 11, 2004 8:50 am     Reply with quote
Timer0 is 16bits also but has an 8bit mode as well.
Henk
PostPosted: Thu Nov 11, 2004 2:24 pm     Reply with quote
Thanx Mark. As advised, a simple test program runs correctly on the existing hardware.
Seems, however, to be some incompatibility with the running of the LCD routine on the new processor, although it runs perfectly on the 877. Addressing is taken care of in the include file 18F452.h, which I also checked against the data sheets.My application program code begins with messages to a 2x16 display, so this gave the impression that the processor was not running. Is this a known problem with the 452?
Mark
PostPosted: Thu Nov 11, 2004 2:43 pm     Reply with quote
Only the problems mentioned hear are the ones that I have seen. Take a baby step and write a simple program to write to the display to make sure those routines are good.
Henk
PostPosted: Sat Nov 13, 2004 12:44 am     Reply with quote
Got it. You were both right. Clever Henk deleted some lines in the standard LCD.C routine to save code space, and set portD address at 8 for 16F877.
thanks again.
