poorly Guest
| reset & WDT |
Posted: Tue Nov 09, 2004 5:43 am |
hiii everybody
I would like to ask about the fuction of reset_cpu command.
If I use reset_cpu command anywhere in the code, Where will the program go?
I mean, CPU starts whether at the beginning of my code (including variable definations) or at the beginning of the main?
Is there any difference, if CPU resets due to the WDT ?
what sort of code (WDT routine) should I write to run in case of overflow of WDT only?
Is there any bit to be tested?
thanks any guy who helps so much.
poorly |
| Re: reset & WDT |
Posted: Tue Nov 09, 2004 6:07 am |
| poorly wrote: | hiii everybody
poorly |
The answer to this, is in the manual, and the device data sheet.
The reset_cpu command, triggers the instruction 'RESET' (on the 18 chips). This has the same effect as a MCLR reset on the processor. So the machine starts just as if this line has been pulled low. The 'restart_cause' command will reflect this. On 16 chips, the command is only a 'simulation', and causes a jump to address 0. As such, the registers are not reset to their 'power on' state, but in both cases, all 'initialisation' in the code will occur.
poorly Guest
Posted: Tue Nov 09, 2004 7:00 am |
Dear Ttelmah
In addition,
Is there any bit to be tested to run a different routine for WDT time out?
thanks a lot
poorly |
Posted: Tue Nov 09, 2004 9:33 am |
| poorly wrote: | Dear Ttelmah
In addition,
thanks a lot
poorly |
Classic example, would be to declare all your variables as uninitialised (and not have #zero_ram). Then have an 'init' function, that sets them to default values, and sets all the chip I/O up (so all the timer initialisation etc.). Then test 'restart_cause', for the watchdog (or other cases), and don't re-initialise on the watchdog.
void init() {
if (restart_cause()==NORMAL_POWER_UP || restart_flag>1) {
restart_flag=0;
//Here do all the port setup, and register setup
else {
++restart_flag;
In your main code, at a point where you are sure everything is working OK, clear 'restart_flag'.
This forces a full reset, if the watchdog timeout (or other reset cause), repeats, without getting to the fully 'running' condition.
You also need to declare variables, which you want to use 'over' the reset (such as restart_flag), by locating them yourself in a RAM area (so they are not automatically initialised).
poorly Guest
| WDT |
Posted: Thu Nov 11, 2004 5:53 am |
OK
thanks |
