Problems reading PORTB inputs
Sensor
PostPosted: Wed Nov 10, 2004 11:42 am     Reply with quote
Connected to RB6 and RB7 are Normally Closed (NC) switches. So normally, RB6 and RB7 should be reading GND, and when the switches are set both should be reading +5V. However, when we read the PORTB register, setting the switch on RB7 actually sets bit 6 of register PORTB instead of bit 7, and setting the switch on RB6 does nothing. What is going on? Here is our complete program. It is actually five separate files but I've put them into one file so I could post it... I have comments where each file ends and begins.
We are using PIC16F627A
Our compiler is the PCW Compiler, IDE version 3.30, PCB version 3.155, PCM version 3.155, and PCH version 3.155
//  THIS IS A SEPARATE FILE - AUTOSENSOR.H
#include <16F627A.h>
#fuses INTRC_IO,NOWDT
/************    END AUTOSENSOR.H   **************/
//  THIS IS A SEPARATE FILE - PROJECT_DEFS.H
// Buttons --- BT = Button
#define BT_RET_Pushed         !input(PIN_A0)
#define BT_RET_NOT_Pushed     input(PIN_A0)
#define BT_EL_Pushed          !input(PIN_A4)
#define BT_EL_NOT_Pushed      input(PIN_A4)
#define BT_TURN_Pushed        !input(PIN_B1)
#define BT_TURN_NOT_Pushed    input(PIN_B1)
#define BT_POWER_Pushed        !input(PIN_B0)
#define BT_POWER_NOT_Pushed    input(PIN_B0)
//LEDs
#define Motion_LED_On         output_high(PIN_A7)
#define Motion_LED_Off        output_low(PIN_A7)
#define Raised_LED_On         output_high(PIN_A3)
#define Raised_LED_Off        output_low(PIN_A3)
#define Travel_LED_On         output_high(PIN_B2)
#define Travel_LED_Off        output_low(PIN_B2)
//Limit Switches --- LS = Limit Switch
#define Down_LS_SET           input(PIN_B3)
//#define Down_LS_NOTSET        !input(PIN_B3)
#define END_LS_SET            input(PIN_B6)
//#define END_LS_NOTSET         !input(PIN_B6)
#define START_LS_SET         input(PIN_B7)
//#define START_LS_NOTSET      !input(PIN_B7)
//Motor Controls
#define Enable_On             output_high(PIN_A6)
#define Enable_Off            output_low(PIN_A6)
#define Phase_On              output_high (PIN_B5)
#define Phase_Off             output_low (PIN_B5)
//Puts entire system to sleep
#define Sleep_Off             output_high (PIN_B4)
#define Sleep_On              output_low (PIN_B4)
/************    END PROJECT_DEFS.H   **************/
// THIS IS A SEPARATE FILE - DEBOUNCE.C
void debounce(void)
         delay_ms(250);
         while(BT_POWER_Pushed || BT_EL_Pushed)
            delay_ms(20);
/************    END DEBOUNCE.C   **************/
// THIS IS A SEPARATE FILE - MOTOR.C
/*******   Motor Truth Table   ***********
   Phase    Enable    Sleep    Function
     1        1         1      Forward
     0        1         1      Reverse
     X        0         1      Brake
     X        X         0      Sleep Mode
void motor_CCW(void)
         Motion_LED_On;
         Phase_On;
         Enable_On;
void motor_CW(void)
         Motion_LED_On;
         Phase_Off;
         Enable_On;
void motor_STOP(void)
         Motion_LED_Off;
         Enable_Off;
/************    END MOTOR.C   **************/
                           MAIN PROGRAM
#include "AutoSensor.h"
#include "project_defs.h"
#include "debounce.c"
#include "motor.c"
#ZERO_RAM
boolean POWER_ON = FALSE;   //Power button
                       Interrupt Function
#int_EXT
EXT_isr() {
   debounce();
   if(POWER_ON)
      POWER_ON = FALSE;
      POWER_ON = TRUE;
     if (POWER_ON)   //Power On
      Sleep_Off;
        Sleep_On;  //Puts everything to sleep
                       Main Function
   Sleep_On;
   port_b_pullups(TRUE);
   setup_counters(RTCC_INTERNAL,WDT_2304MS);
   setup_timer_1(T1_DISABLED);
   setup_comparator(NC_NC_A1_A2);
   setup_vref(FALSE);
   enable_interrupts(global);
   enable_interrupts(INT_EXT);
  while(TRUE){
      while (POWER_ON)
          // if neither button is pushed, Brake
                if (BT_TURN_NOT_Pushed && BT_RET_NOT_Pushed)
                     motor_STOP();
            // if Turn is pushed, rotate counterclockwise
                while (BT_TURN_Pushed)
                          if (END_LS_SET)
                           motor_STOP();
                           motor_CCW();
            // if RETURN is pushed, rotate clockwise
                while (BT_RET_Pushed)
                          if (START_LS_SET)
                               motor_STOP();
                              Raised_LED_On;
                           motor_CW();
                                Sleep Mode
       setting PIN_A2 high gives lowest sleep current
      setup_comparator(NC_NC_NC_NC); // disable comparator
      output_high (PIN_A2);
      #ASM
         SLEEP
         NOP
      #ENDASM
      output_low (PIN_A2);
Humberto
PostPosted: Wed Nov 10, 2004 12:47 pm     Reply with quote
change to:
#fuses INTRC_IO,NOWDT,NOLVP,NOPROTECT
Humberto
Mark
PostPosted: Wed Nov 10, 2004 12:51 pm     Reply with quote
Are you using an ICD to read PORTB?
Sensor
PostPosted: Wed Nov 10, 2004 12:55 pm     Reply with quote
that wasn't it. But thanx anyway Humberto
Sensor
PostPosted: Wed Nov 10, 2004 1:00 pm     Reply with quote
To Marks question....
We are using the MPLAB ICE 2000, with MPLAB version 6.60. We are reading the register PORTB under special function registers in MPLAB v6.60.
Mark
PostPosted: Wed Nov 10, 2004 1:03 pm     Reply with quote
I would check the hardware.
Sensor
PostPosted: Wed Nov 10, 2004 1:07 pm     Reply with quote
We think we exausted that possibility but we can do that again. The last physical connection (RB7) going into the emulator will behave as expected. i.e it WILL go high when we set the switch, but the PORTB register does not correspond to that, namely it registers it as a RB6 change.
Also the Input change on RB6 does register on the last physical connection to the emulator, but when we read the PORTB register, no changes are registered.
Mark
PostPosted: Wed Nov 10, 2004 1:10 pm     Reply with quote
Have you tried a real chip? Its possible that the emulator pod is bad.
Sensor
PostPosted: Wed Nov 10, 2004 1:14 pm     Reply with quote
We have not tried a real chip yet. However I want to mention this though:
If we do a simple command
output_high(PIN_B7);
we DO see a change in the register, namely it does go high on RB7
Mark
PostPosted: Wed Nov 10, 2004 1:16 pm     Reply with quote
The input buffers are different from the outputs. You can blow em up (inputs) and the outputs still work okay.
Sensor
PostPosted: Wed Nov 10, 2004 1:19 pm     Reply with quote
is there any way to verify that
Humberto
PostPosted: Wed Nov 10, 2004 2:24 pm     Reply with quote
IMO you must reduce your code to minimum, at least to the level were you
feel confidence with the hardware, software and tools you are using.
Just an input switch and an output LED.
      if (END_LS_SET)
          Led_OFF;
          Led_ON;
Then and only when the hardware does what you coded, you have a real case to post
the results or behaviour, meanwhile you are playing with "virtual" inputs and outputs.
HTH,
Humberto Very Happy
Sensor
PostPosted: Mon Nov 15, 2004 10:54 am     Reply with quote
@ Mark
and everybody else...
Thanx. It turns out that our emulation kit is defective. We did sucessfully program the real chip and it is behaving as expected.
Thanx again for all of your help
