ccmcca Guest
BITMAP |
Posted: Sat Nov 06, 2004 12:55 pm |
Anybody knows how can i do this?????
I have a 128 * 64 lcd and i want to show a bitmap.-
i declare a CONST string whith the hex locations but is not enought....
thanks.-
[/b] |
Mark
Posted: Sat Nov 06, 2004 8:21 pm |
Well with the info you gave the only answer is to store the bitmap in flash and then display it. |
Trampas
Posted: Sun Nov 07, 2004 7:16 am |
Yes, I am sure several of us know how to do it.
1) design board with some large external memory.
2) make and populate board
3) write drivers for LCD and memory
4) load external memory with bitmap
5) parse bitmap and display on LCD
Of course this does not answer you question, but we do not know what your question really is.
Here is a little joke:
A man in a ballon is lost and sees a guy walking down a road. He lowers the ballon and asks the guy, "Excuse me but could you tell me where I am?" The guy on the road looks up and says "Yes, you are in a ballon." The guy in the ballon, says "You must be an engineer."
"Why yes I am, how did you know."
"You gave me a technically correct answer that was no use to me."
After a brief pause the engineer looked at the guy in the ballon and said:
"You must be a manager." To which the guy in the ballon was surpised and said "Why, yes I am, how did you know?"
"Because you got yourself lost, and some how it has become my problem."
Trampas |
ccmcca Guest
BITMAP |
Posted: Sun Nov 07, 2004 9:37 am |
#include <16F877.h>
#device *=16
#include <HDM64GS12.c>
#include <graphics.c>
//CHAR const my_string[22]="hola amicomo vasssslr";
char const rawData[256] =
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0x00, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xC7, 0xFF, 0xFF, 0xFF,
0xF8, 0x7E, 0x7F, 0xFF, 0xE7, 0xCF, 0xFF, 0xFF,
0xE3, 0xFF, 0x9F, 0xFF, 0xE0, 0xC7, 0xFF, 0xFF,
0x8F, 0xFF, 0xCF, 0xFF, 0xF8, 0x33, 0xFF, 0xFF,
0x3F, 0xFF, 0xEF, 0xFF, 0xFF, 0x7D, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xC7, 0xFF, 0xFF, 0xFE,
0x7F, 0xFF, 0xF7, 0xFF, 0xFE, 0x7D, 0xFF, 0xFF,
0xF8, 0x1E, 0x07, 0x81, 0xC0, 0x78, 0x1F, 0xFC,
0xFF, 0xFF, 0xF3, 0xFF, 0xFE, 0xFD, 0xFF, 0xFF,
0xF0, 0x0C, 0x03, 0x00, 0xC0, 0x30, 0x1F, 0xF9,
0xFF, 0xFF, 0xFB, 0xFF, 0xFC, 0xF9, 0xFF, 0xFF,
0xF1, 0x8C, 0x63, 0x18, 0xC6, 0x31, 0xFF, 0xFB,
0xFF, 0xFF, 0xF9, 0xFF, 0xFC, 0xF9, 0xFF, 0xFF,
0xFF, 0x8C, 0x7F, 0x18, 0xC6, 0x31, 0xFF, 0xFB,
0xFF, 0xFF, 0xFD, 0xFF, 0xFC, 0xF9, 0xFF, 0xFF,
0xFF, 0x0C, 0x7F, 0x18, 0xC6, 0x30, 0x0F, 0xF3,
0xFF, 0xFF, 0xFD, 0xFF, 0xFD, 0xF9, 0xFF, 0xFF,
0xFF, 0x1C, 0x7F, 0x18, 0xC6, 0x30, 0x0F, 0xF3,
0xFF, 0xFF, 0xFD, 0xFF, 0xF9, 0xF9, 0xFF, 0xFF,
0xFC, 0x3C, 0x7F, 0x18, 0xC6, 0x31, 0x8F, 0xF7,
0xF8, 0x3C, 0x63, 0x18, 0xC6, 0x31, 0x8F, 0xF7,
0xF8, 0xFC, 0x63, 0x18, 0xC6, 0x31, 0x8F, 0xF7,
0xF1, 0xFE, 0x07, 0x81, 0xC0, 0x78, 0x1F, 0xF7,
0xFF, 0xFF, 0xF9, 0xFF, 0xF9, 0xF9, 0xFF, 0xFF,
char const rawData2[256] =
0xF1, 0x8E, 0x07, 0x81, 0xC0, 0x78, 0x1F, 0xF3,
0xF1, 0x8F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF3,
0xFF, 0xFF, 0xFB, 0xFF, 0xF9, 0xF9, 0xFF, 0xFF,
0xF8, 0x1F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFB,
0xFF, 0xFF, 0xF3, 0xFF, 0xF9, 0xF9, 0xFF, 0xFF,
0xFF, 0xFF, 0xF7, 0xFF, 0xF8, 0xF9, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFD,
0xFF, 0xFF, 0xE7, 0xFF, 0xFC, 0xF9, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC,
0xFF, 0xFF, 0xCF, 0xFF, 0xFC, 0xF9, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE,
0x7F, 0xFF, 0x9F, 0xFF, 0xFC, 0x79, 0xFF, 0xFF,
0x3F, 0xCF, 0x3F, 0xFE, 0xFE, 0x31, 0xFF, 0xFF,
0x9F, 0xCC, 0x7F, 0xFE, 0x7E, 0x31, 0xFF, 0xFF,
0xFF, 0xFF, 0xFC, 0x07, 0xFF, 0xFF, 0xFF, 0xFF,
0xC7, 0xC1, 0xFF, 0xFE, 0x7F, 0x01, 0xFF, 0xFF,
0xFF, 0xFF, 0xFC, 0x03, 0xFF, 0xFF, 0xFF, 0xFF,
0xF1, 0xCF, 0xFF, 0xFF, 0x3F, 0x03, 0xFF, 0xFF,
0xFF, 0xFF, 0xFC, 0x63, 0xFF, 0xFF, 0xFF, 0xFF,
0xF9, 0xCF, 0xFF, 0xFF, 0x83, 0x01, 0xFF, 0xFF,
0xF9, 0xCF, 0xFF, 0xFF, 0xE3, 0x01, 0xFF, 0xFF,
0xFB, 0xCF, 0xFF, 0xFF, 0xE6, 0x00, 0xFF, 0xFF,
0xF3, 0xEF, 0xFF, 0xFF, 0xCE, 0x00, 0xFF, 0xFF,
0xF3, 0xFF, 0xFF, 0xFF, 0x9E, 0x00, 0xFF, 0xFF,
char const rawData3[256] =
0xF8, 0xDF, 0xFF, 0xFE, 0x7E, 0x00, 0xFF, 0xFF,
0xFE, 0x1F, 0xFF, 0xFC, 0xFE, 0x00, 0x7F, 0xFF,
0xFE, 0x7F, 0xFF, 0xF9, 0xFE, 0x00, 0x7F, 0xFF,
0xFE, 0x7F, 0xFF, 0xF3, 0xFF, 0x00, 0x7F, 0xFF,
0xFF, 0xFF, 0xFC, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF,
0xFE, 0xFF, 0xFF, 0xF3, 0xFF, 0x00, 0x7F, 0xFF,
0xFF, 0xFC, 0x0C, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF,
0xFE, 0xFF, 0xFF, 0xF1, 0xFF, 0x00, 0x7F, 0xFF,
0xFF, 0xF8, 0x0C, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF,
0xFC, 0xFF, 0xFF, 0xFE, 0x7F, 0x00, 0xFF, 0xFF,
0xFF, 0xF8, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xED, 0xFF, 0xFF, 0xFF, 0x9F, 0x80, 0xFF, 0xFF,
0xE9, 0xFF, 0xFF, 0xFF, 0xC7, 0x80, 0xFF, 0xFF,
0xFF, 0xF8, 0x07, 0xFF, 0xFF, 0xFF, 0xFF, 0xFD,
0xFB, 0x8F, 0xFF, 0xFF, 0xE1, 0x80, 0x7F, 0xFF,
0xFF, 0xF8, 0x07, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE,
0x3B, 0x9F, 0xFF, 0xFF, 0xF0, 0x80, 0x1F, 0xFF,
0xFF, 0xF8, 0xC7, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0x3F, 0xFF, 0xFF, 0xFF, 0xF8, 0x00, 0x0F, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xC3, 0x87, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xE3, 0xFF,
0xFF, 0xFC, 0x0F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE,
0x3E, 0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xF9, 0xFF,
0xFF, 0xFC, 0x0F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFC,
0xF7, 0x3F, 0xFF, 0xFF, 0xFF, 0x87, 0xFC, 0xFF,
char const rawData4[256] =
0xF8, 0x1F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xF7, 0xBF, 0xFF, 0xFF, 0xF3, 0x03, 0xFE, 0x7F,
0xF0, 0x0E, 0x1F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xF7, 0xFF, 0xFF, 0xFF, 0xF8, 0x03, 0xFF, 0x3F,
0xF1, 0x8E, 0x0F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xF7, 0xFF, 0xFF, 0xFF, 0xFE, 0x01, 0xFF, 0xCF,
0xFF, 0x8F, 0x8F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0x01, 0xFF, 0xE7,
0xFF, 0x0F, 0x87, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0x1F, 0x87, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0x01, 0xFF, 0xCF,
0xFC, 0x3F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0x01, 0xFF, 0x3F,
0xF8, 0x3F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0x03, 0xFC, 0x7F,
0xF8, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0x03, 0xF1, 0xFF,
0xF1, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFC, 0x07, 0xC7, 0xFF,
0xF1, 0x8F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0x01, 0x1F, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0x00, 0x7F, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x31, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x73, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x87, 0xFF, 0xFF,
0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xCF, 0xFF, 0xFF,
glcd_init(ON);
this is my program with my bitmap in ROM.....
Same ideas to show the array?
Thanks again.
#ifdef FAST_GLCD
glcd_update();
#else
delay_ms(100); // Reduces flicker by allowing pixels to be on
// much longer than off
Posted: Sun Nov 07, 2004 3:48 pm |
I would suggest to read the data from ROM and write it to your display. Just as simple as that...
Somehow I guess that's not the answer you were waiting for, so please explain were your problem is. Is it in reading the data from ROM, or in the writing to your display? |
BMP in external eeprom library |
Posted: Mon Nov 08, 2004 6:58 am |
I store my bmp in an external i2c eeprom (24LC512), you can store 64 bmp. use an bmp to bin converter and prog the bin file in the eeprom
and i wrote a function for read each eeprom byte and write in the glcd.
//// Transfert d'une image ////
//// de 128 * 64 d'une eeprom vers le LCD ////
//// - Donnees : adresse de l'image dans l'eeprom ////
void glcd_image(int16 adresse)
int8 *p1, *p2;
int8 i, j;
p1 = displayData.left;
p2 = displayData.right;
for(i=0; i<8; ++i)
for(j=0; j<128; ++j)
if (j<64)
*p1++ = read_ext_eeprom(adresse++);
else *p2++ = read_ext_eeprom(adresse++);
in my code i call the function like this
#define INTRO 0x1000
glcd_image(INTRO);
glcd_update();
i wrote also an pseudo sprite function for display a little bmp like big font or animated bargraph...
//// d'une eeprom vers le LCD ////
//// - col : largeur en pixel de l'image ////
//// - lig : hauteur en ligne de l'image ////
//// - x : coordonnée horizontale ou afficher l'image (en pixel) ////
//// - y : coordonnée verticale ou afficher l'image (en ligne) ////
//// - adresse : adresse de l'image dans l'eeprom ////
void glcd_sprite(int8 col, lig , x , y , int16 adresse)
int8 *p;
int8 i, j, data;
int16 temp;
for(i=0; i<lig; ++i)
temp = y + i;
temp *= 64;
temp += x;
for(j=0; j<col; ++j)
p = temp + j;
if(x + j > 63)
p += displayData.right - 64;
p += displayData.left;
*p = read_ext_eeprom(adresse++);
the call sequence is in this exemple
adresse = LGE_FONT + (30 * (int16) digit[d]);
glcd_sprite(15,2,x,y,adresse);
glcd_update();
LGE_FONT is the start adress for my large font (15 pixel wide x 2 lines (16 pixel))
the LGE_FONT + (30 * (int16) digit) expression compute the offset of the digit
The limit of this second function is the Y position must be a line multiple and not real 0<y<64 coordinate. Maybe for the future...!!
In my eeprom, i store 10 bmp (0.bin + 1.bin + ... +9.bin), each digit (x.bin) is 30 byte long (15 pixel * 2 lines).
With this 2 functions, is very easy to make a beautiful (!) LCD interface.
you must use a 24xxx.c library, i modify the 24256.c to make a 24512 library... only the size of the memory.
I hope that help you.
My english is very approximate ! i'm living in Avignon - France. I read it much better than i wrote it !!
Thierry |
treitmey
action2003
Joined: 08 Nov 2004 Posts: 2 Location: Avignon - France
Posted: Tue Nov 09, 2004 7:47 am |
what's a good link, i never write my function if i know it before
But, i'm a "C" beginner , and i just translate my Proton basic pic sub-routine to CCS function.
I search scroll and roll sprite function for a GLCD.
Thierry as Guest _________________ Thierry - Avignon - France |
Orcino
Posted: Tue Mar 15, 2005 2:41 pm |
Hello, I am having problem to execute the function placed for guest, somebody can help me with an example ?
Orcino |
