hwwspace Guest
| IF statment |
Posted: Thu Nov 04, 2004 3:40 am |
I am a new one to use CCS C compiler. I am using 16F73 with CCS PCM 3.211 Compiler. I have some problem with my code. I want to get the atan value from two inputs AN0 and AN1, then output PWM in ccp1. Is there someone can help me?
the code is following:
#include <16F73.h>
#include <math.h>
#device adc=8
#use delay(clock=2000000)
#fuses NOWDT,XS, NOPUT, NOPROTECT, BROWNOUT
void main() {
float valueX, valueY, data, angle;
setup_adc_ports(AN0_AN1_AN3);
setup_spi(FALSE);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_1,255,1);
setup_ccp1(CCP_PWM);
setup_ccp2(CCP_PWM);
while(true){
set_adc_channel(0);
delay_us(10);
valueX = read_adc();
set_adc_channel(1);
delay_us(10);
valueY = read_adc();
valueX = (valueX - 128) / 128;
valueY = (valueY - 128) / 128;
data = valueY / valueX;
if(valueX > 0){
if(valueY > 0)
angle = atan(data);
angle = 6.2831853 + atan(data);
else{
angle = 3.14159265 + atan(data);
angle = angle * 1024 / (2.0 * PI);
set_pwm1_duty((long int) angle);
drh
Joined: 12 Jul 2004 Posts: 194 Location: Hemet, California USA
Posted: Thu Nov 04, 2004 8:36 am |
A couple of suggestions:
Enable PUT in your #fuses statement.
Cast your adc value to a float.
i.e. valueX = (float)read_adc(); _________________ David |
