Rainer Guest
bug in PCH .DLL (Version 3.149) |
Posted: Sat Mar 29, 2003 8:05 am |
If I use the newest version of PCH (3.149) and MPLAB 6.13 the compiler hangs with a PCH.DLL error.
If I downgrade to Version 3.148 everything works fine. What is wrong?
___________________________
Original Post ID: 13224 |
Jerry Finsen Guest
Re: bug in PCH .DLL (Version 3.149) |
Posted: Sat Mar 29, 2003 8:14 am |
I have had to roll back to the 3.148 too. 3.149 compiler crashes while compiling. I reported it and am awaiting a resolution
Original Post ID: 13226 |
Lance Lascari Guest
Posted: Sat Mar 29, 2003 8:19 am |
I reported this a few days ago as well... they sent me an updated dll... but going back to 3.148 worked fine too.
In my case it would hang when generating a legitimate error (i.e. a bug in my code), but when the error was corrected it seemed to fix the problem (I didn't however know that there was a typo until I reverted back and got the error).
Lance
:=I have had to roll back to the 3.148 too. 3.149 compiler crashes while compiling. I reported it and am awaiting a resolution
Original Post ID: 13227 |
Paul Holthuizen Guest
Posted: Mon Mar 31, 2003 4:18 am |
:=I reported this a few days ago as well... they sent me an updated dll... but going back to 3.148 worked fine too.
:=In my case it would hang when generating a legitimate error (i.e. a bug in my code), but when the error was corrected it seemed to fix the problem (I didn't however know that there was a typo until I reverted back and got the error).
:=Lance
:=:=I have had to roll back to the 3.148 too. 3.149 compiler crashes while compiling. I reported it and am awaiting a resolution
Did the updated dll work for you? For me it didn't, so I keep using 3.148 for now.
Paul
Original Post ID: 13246 |
lance_lascari Guest
Posted: Mon Mar 31, 2003 7:32 am |
Yes, it did work for me. Perhaps there are a variety of nuances that are only partially fixed.
Interestingly, if I open the IDE (which I rarely use), and do "help->about" I get
PCB 3.49
PCM 3.49
PCH 3.50
-Lance
:=:=I reported this a few days ago as well... they sent me an updated dll... but going back to 3.148 worked fine too.
:=:=In my case it would hang when generating a legitimate error (i.e. a bug in my code), but when the error was corrected it seemed to fix the problem (I didn't however know that there was a typo until I reverted back and got the error).
:=:=Lance
:=:=:=I have had to roll back to the 3.148 too. 3.149 compiler crashes while compiling. I reported it and am awaiting a resolution
:=Did the updated dll work for you? For me it didn't, so I keep using 3.148 for now.
:=Paul
Original Post ID: 13250 |
