correct baudrate setting?
davt
PostPosted: Fri Oct 29, 2004 9:33 am     Reply with quote
Hi all
I am trying to set up the baudrate in a 16F767 running at 16.0 mhz, to 250 000.
Can someone please confirm that I have got my settings right from the code below:
spbrg=0x00; // set up
brgh=low; // baudrate to 250.000
sync=0; // enable asynchronous reception
spen=1; // serial port enabled - rc7/rx/dt , rc6/tx/ck pins as serial port pins
rx9=1; // 9 bit reception
Many thanks.
Dave
SherpaDoug
PostPosted: Fri Oct 29, 2004 10:53 am     Reply with quote
Why not:
#use rs232(baud=250000,xmit=rc7,rcv=rc6)
The compiler has no problem with oddball baud rates.
davt
PostPosted: Mon Nov 01, 2004 9:21 am     Reply with quote
Hi Doug
Thanks for your reply.
I need to use the internal hardware usart, I thought the # use rs232 was the software usart?
But any way I want to use the settings:
Will these settings give me 250.000 baudrate @ 16.000 mhz.
Thanks again
Dave
John Morley
PostPosted: Mon Nov 01, 2004 9:43 am     Reply with quote
Dave,
The #use rs232 statement works for both hardware AND software USART's. The compiler recognizes that you want to use the hardware USART if:
1. the device supports a hardware USART
2. you have specified the hardware USART pins
Otherwise the compiler just creates a software USART with the pins specified.
John Morley
davt
PostPosted: Mon Nov 01, 2004 10:10 am     Reply with quote
Hi John
How do I incorporate 9th bit reception?
Many thanks.
Dave
John Morley
PostPosted: Mon Nov 01, 2004 10:34 am     Reply with quote
Dave,
One of the options in the #use rs232 state will do this. Insert Bits=9
#use rs232(baud=9600, xmit=PIN_A2, rcv=PIN_A3, bits=9, .......)
Valid number for Bits= range from 5 to 9.
Good Luck!
John Morley
