ninjanick
Code Protection and Potential Upgrades? |
Posted: Tue Oct 26, 2004 3:48 pm |
I know Code Protection is possilbe, but I have a situation where future upgrades are a possibility. I thought of opening the EEPROM Memory so that I can read the build date, revision, etc ... since it's not vital to protect. A question came to me recently and I'm having a hard time answering.
What happens if someone reads the EEPROM and writes these values back to another chip. Sends the chip in for "upgrade" and gets a brand new upgraded chip for the price of a blank. Anyway to get around this? I can't read the Program Memory as it's protected and if I plug the chip in to a test board and it doesn't work ... all the "customer" can say is it didn't work from the beginning. Or am I thinking about this too hard? |
Trampas
Posted: Wed Oct 27, 2004 7:05 am |
You are thinking too hard...
First off what if some one zaps a new chip and then sends it back to you?
So basically worring too much about it may be overkill. Just make you a security sticker and put on the chip. Then only warrenty chips with the security sticker.
Trampas |
Mark
Posted: Wed Oct 27, 2004 8:50 am |
I agree that you are thinking too hard also. But, you can have the version hardcoded in the code and check the eeprom. If its different, then write the data to it. The eeprom will always have the correct version and you will be able to read it. |
ninjanick
Posted: Thu Oct 28, 2004 3:15 pm |
Thanks! I think the security sticker is the way to go. Anyone know a good vendor that has a sticker that will fit on an 18-pin dip? |
