RS232 receptacle on CCS's CANBUS kit...
MikeValencia
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Thu Oct 28, 2004 11:04 am     Reply with quote
Does anyone have the part number and manufacturer of the nifty little RS232 receptacle on CCS's CANBUS kit?
Instead of using your standard 9-pin rs232 cable, they use a plug in receptacle with 3 contacts.
Thanks,
Mike
Will Reeve
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Thu Oct 28, 2004 11:38 am     Reply with quote
They use a 3.5mm jack plug on the USB kit, like a headphone connector?
Will
PostPosted: Thu Oct 28, 2004 12:24 pm     Reply with quote
Judging from the photo about half-way down this page,
http://www.ccsinfo.com/canbusdvkt.shtml
those look like CUI 3.5mm jacks, probably with the non-threaded bushing. Here's the page:
http://www.cui.com/adtemplate.asp?invky=313381&catky=619701&subcatky1=749477&subcatky2=859248
There are three different models, depending on whether it has shorting
shunts on it. I can't really tell from the photo. If you have the board
you can tell. Digikey sells these connectors.
valemike
PostPosted: Thu Oct 28, 2004 12:46 pm     Reply with quote
Will,
Yes, it looks like a headphone connector.
PCMPro,
that's it! My board has the threaded bushing though. But other than that, the metal inside and their positioning (since the case is see-thru) is absolutely identical.
valemike
PostPosted: Thu Oct 28, 2004 12:49 pm     Reply with quote
I forgot to mention that it has 3 contacts.
I don't know what you mean though by shorting shunts.
PostPosted: Thu Oct 28, 2004 1:03 pm     Reply with quote
Go here to the main CUI connector page. It will take you
to the parts with threaded bushings.
http://www.cui.com/catfeatures.asp?catky=619701&subcatky1=749477
"Shorting shunts" was the phrase I used to describe the little
spring loaded contacts that can be used to short the left and
right channel pins to ground, when a stereo plug is not inserted
into the jack.
You might do this if you want to hold the inputs of an amplifier
at 0 volts when there is no audio input. ie., to prevent noise
from being amplified and propagated through the system when
you actually have no input signal connected to your board.
This is irrelevant to the RS-232 usage. You wouldn't need the
shunts in that case.
valemike
PostPosted: Thu Oct 28, 2004 2:36 pm     Reply with quote
Thanks for the explanation PCMPro.
CCS did answer me back and told me the exact part number is:
Mouser (and Manufacturer's) Part #: 161-3501
I was curious because i might put this on my first spin of the board for
debugging purposes. Nothing better than a printf() to Hyperterminal to debug problems without interrupting execution of your program.
