Is this an error from CCS?
chen
PostPosted: Wed Oct 27, 2004 2:40 pm     Reply with quote
I define
#bit GRNLED_SEL = PORTF.2
#bit MMCPOWERE = TRISF.3
#bit MMCPOWER = LATF.3
When I assign GRNLED_SEL=1, it affects the state of MMCPOWER.
chen
PostPosted: Wed Oct 27, 2004 2:41 pm     Reply with quote
BTW, I am using PIC18F8620 with CCSC 3.212
and I initialize MMCPOWERE =0
dyeatman
We need more information!
PostPosted: Wed Oct 27, 2004 3:00 pm     Reply with quote
It would be nice to see ALL of your initialization/setup source code which includes showing the include file(s) you are using.
Also post the portion of the LISTing file around the instructions you posted so we can see what the compiler is doing.
Trampas
PostPosted: Wed Oct 27, 2004 3:54 pm     Reply with quote
Also read about the fast I/O if the fast I/O is not selected then setting a port's bit might change the Tris register.
PostPosted: Wed Oct 27, 2004 4:07 pm     Reply with quote
You're probably having a RMW problem. Try doing all operations
on the latch, instead of the port. That should eliminate the problem.
Change the definition of the Green LED bit to use the Latch. Example:
#bit GRNLED_SEL = LATF.2
See this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=19130
Also read the Microchip Reference manual on the i/o ports for 18F PICs:
http://ww1.microchip.com/downloads/en/DeviceDoc/39511.pdf
chen
PostPosted: Thu Oct 28, 2004 12:16 pm     Reply with quote
Thanks, I will follow your suggestions
