jptalledo Guest
Optimize 2 servo control program |
Posted: Wed Oct 27, 2004 6:37 am |
Hi everyone
I will post my code to control 2 servos using timer0 and two variables : Posservo0 and Posservo1 to control the pulse for each servomotor
please if someone could help me to optimize the code I will be very pleased.
#include <16F876A.h>
#device adc=8
#fuses NOWDT,HS, PUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD, NOWRT
#include "C:\Documents and Settings\Jean Paul\My Documents\servo.h"
#include <stdio.h>
#include <string.h>
#define PinServo0 PIN_B4
#define PinServo1 PIN_B5
int PosServo0;
int PosServo1;
int flag;
int i = 0;
int j;
#int_TIMER0
TIMER0_isr()
output_high(PinServo0);
output_high(PinServo1);
delay_us(800);
flag=0;
i=0;
j=0;
while(flag==0)
delay_us(5);
i=i+1;
if (i==PosServo0)
output_low(PinServo0);
j=j+1;
if (i==PosServo1)
output_low(PinServo1);
j=j+1;
if (j==2)
flag=1;
byte Sync = 0; // 0xFF
byte ServoNo = 0; // 1 - 255
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_128);
PosServo0 = 127; // default servo pos
while (TRUE)
if (kbhit())
Sync = getc();
if (Sync==0xFF)
PosServo0= getc();
PosServo1= getc(); // 0-255
Trampas
Posted: Wed Oct 27, 2004 11:04 am |
First look at the fast I/O capabilities of CCS.
Second consider redesigning program, that is having a delay function in a ISR may not be the best method.
Second where possible instead of using ints for variables like flag, use a bit. This may take less time for if(flag==0).
Of course the biggest thing is look at the assembly generated and play with the code.
Trampas |
