newguy
Confirmation please - compiler bug |
Posted: Tue Oct 26, 2004 9:30 am |
Hi all,
I have ver 3.178 of the compiler (pcb, pcm & pch). I ran into a problem about a week ago and last night I finally nailed it.
I have a 18F452 with a 20 MHz crystal - HS mode. I measured the frequency on the pic's osc pins and it is indeed a stable 20 MHz. Anyway, here's the problem:
I used the compiler's setup wizard to create the project, and I wanted only one interrupt: timer0. I wanted it to be driven from the internal clock source, with no division, and 8 bits. The wizard correctly states that the overflow will be 51.2 us. (200 ns internal clock * 256 = 51.2 us)
The relevant code generated by the CCS wizard is:
Code: | setup_timer_0(RTCC_INTERNAL|RTCC_8_BIT); |
So I stupidly thought that it was indeed generating an interrupt every 51.2 us (I don't load timer0 with any value at all - I just let it run). Turns out my project behaved strangely, and it seemed to be a timing problem. Well the interrupt was occurring every 104 us, as measured by a scope. The ISR itself only takes a few cycles to run - basically just toggle a couple of lines, and that's it - therefore it's not a case of the ISR taking more than 51.2 us to execute and missing every odd timer0 overflow.
The .lst file had the answer: the code above loads the T0CON register with 0xC0 - which sets up timer0 with internal clock, but divided by 2!!!! The proper value should be 0xC8. If I manually set T0CON to 0xC8, the interrupt occurs every 51.2 us, just as it should.
Just wondering if CCS has fixed this in newer releases of the compiler? I checked the revision history, and I can't find any mention of timer0 since 3.178. Can anyone confirm this bug in the newest version of the compiler? If so, I'll report it to CCS. |
Posted: Tue Oct 26, 2004 10:08 am |
confirmed with 3.212, but not tested with my proto-board
.................... setup_timer_0 ( RTCC_INTERNAL | RTCC_8_BIT );
0018: MOVLW C0
001A: MOVWF T0CON
workaround: try using RTCC_DIV_256 instead of RTCC_8_BIT
.................... setup_timer_0 ( RTCC_INTERNAL | RTCC_DIV_256 );
001C: MOVLW 87
001E: MOVWF T0CON
or, go edit the header file ... 18F452.H ... over here
#define RTCC_8_BIT 0x40 // modify to 0x48
and ... 18F458.H ... and ... all the 18Fxxx.H
you should file a bug report.
Thanks a lot and best wishes |
Posted: Tue Oct 26, 2004 10:27 am |
sorry, RTCC_DIV_256 won't work, my mistake.
time to sleep ... bye. |
Not a bug |
Posted: Tue Oct 26, 2004 10:33 am |
18F452.H
Code: | #define RTCC_DIV_1 8
#define RTCC_DIV_2 0
#define RTCC_DIV_4 1
#define RTCC_8_BIT 0x40 |
so, the right way to set it up is ...
setup_timer_0 ( RTCC_INTERNAL | RTCC_8_BIT | RTCC_DIV_1 );
Cheers ![Very Happy](images/smiles/icon_biggrin.gif) |
newguy
Posted: Tue Oct 26, 2004 11:32 am |
Actually, I tried that. I don't know what happened, but I can tell you that my application stopped running completely. As soon as I set the T0CON register manually to the correct value, then it worked.
My point is that the *wizard* told me that the timer0 overflow will be 51.2 us, when it is in fact 104 us. Either way, it's still a bug. |
Posted: Tue Oct 26, 2004 11:38 pm |
Yes, there is a bug, somewhere. I suggest to call it a "Wizard bug", or, "IDE bug", instead of compiler bug. The buggy one is pcw.exe, the IDE.
I am happy with the following code telling me that ccsc.exe and pch.dll, the compiler, is ok.
.................... setup_timer_0 ( RTCC_INTERNAL | RTCC_8_BIT | RTCC_DIV_1 );
0014: MOVLW C8
0016: MOVWF T0CON
0018: MOVLW C0
001A: MOVWF T0CON
.................... *(int8 *)0xFD5 = 0xC8;
001C: MOVLW C8
001E: MOVWF T0CON
Best wishes ![Very Happy](images/smiles/icon_biggrin.gif) |
