Port G & F
Port G & F
PostPosted: Tue Oct 26, 2004 1:27 pm     Reply with quote
Port G & F are digital ports multiplexed with peripherals.
It is a little confusing to me how to set them all up for digital I/O.
In my codes, if I just set up TRIS and LAT registers, it some times work, but not always
Thanks for your time!
PostPosted: Tue Oct 26, 2004 1:36 pm     Reply with quote
Also, since I use
setup_adc(NO_ANALOGS);
and do not enable any comparators, shouldn't all F&G port be set up as digital IO correctly?
PostPosted: Tue Oct 26, 2004 1:59 pm     Reply with quote
I added these to my initialization codes, and still have the problem
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
setup_ccp3(CCP_OFF);
setup_ccp4(CCP_OFF);
setup_ccp5(CCP_OFF);
PostPosted: Tue Oct 26, 2004 2:05 pm     Reply with quote
What PIC are you using ? And, what compiler and what version ?
PostPosted: Tue Oct 26, 2004 2:09 pm     Reply with quote
PIC18F8620
I tried both 3.186 and 3.212
