Structure pointer syntax question
object01
PostPosted: Mon Oct 25, 2004 12:20 pm     Reply with quote
I'm trying to understand why one of the statements in the following code works, but the other doesn't. Am I missing some subtlety of the syntax?
#include <18F2320.h>
struct STRUCTDEF {
   unsigned int8 field1;
struct STRUCTDEF * __STACK[8];
unsigned int8  __STACKTOP = 0;
struct STRUCT_ATINFO * getStackTop() {
   return __STACK[__STACKTOP];
#define getStackTop() (__STACK[__STACKTOP])
void main() {
   struct STRUCTDEF s;
   struct STRUCTDEF *sPtr;
   unsigned int8 value;
   s.field1 = 42;
   __STACK[__STACKTOP] = &s;
   // If this works,
   sPtr = getStackTop();
   value = sPtr->field1;
   // then why doesn't this work?
   value = (getStackTop())->field1;
Jeff S.
object01
PostPosted: Mon Oct 25, 2004 12:24 pm     Reply with quote
Casting the macro result like so,
#define getStackTop() ((struct STRUCTDEF *)__STACK[__STACKTOP])
seems to solve the problem, but I don't understand why. Can't the compiler infer the type with the array name alone?
Jeff S.
object01
PostPosted: Mon Oct 25, 2004 1:03 pm     Reply with quote
Another curiosity. Why doesn't using a typedef for the array type and function return type work?
Jeff S.
struct STRUCTDEF {
typedef struct STRUCTDEF *STRUCTPTR;
STRUCTPTR __STACK[8];
STRUCTPTR getStackTop() {
//#define getStackTop() ((struct STRUCTDEF *)__STACK[__STACKTOP])
void main() {
   struct STRUCTDEF s;
   s.field1 = 42;
   __STACK[0] = &s;
   // If this works,
   value = getStackTop()->field1;
