Tullos Guest
DS1307 Real Time Clock question |
Posted: Wed Jul 14, 2004 9:26 pm |
This is the value I get constantly, even if I remove the crystal... I assume something is wrong if I can remove the crystal and nothing changes. Any Ideas?
25/45/-91 45:85:85
25/45/-91 45:85:85
25/45/-91 45:85:85
25/45/-91 45:85:85
Here is the code,
// ds1307.c -- Functions for the Dallas Semiconductor DS1307
// real time clock and NVRAM chip.
// The DS1307 uses BCD as its internal format, but we use it
// in binary format, outside of this module. So we have code
// to convert to/from BCD to binary in the functions below.
// Set the date and time.
The registers inside the ds1307 are in this format. The values are in BCD.
DS1307_SECONDS_REG 0
DS1307_MINUTES_REG 1
DS1307_HOURS_REG 2
DS1307_DAY_OF_WEEK_REG 3 // We don't use this register. Set it to 0.
DS1307_DATE_REG 4
DS1307_MONTH_REG 5
DS1307_YEAR_REG 6
#define DS1307_I2C_WRITE_ADDR 0xd0
#define DS1307_I2C_READ_ADDR 0xd1
// DS1307 register offsets
#define DS1307_SECONDS_REG 0
#define DS1307_MINUTES_REG 1
#define DS1307_HOURS_REG 2
#define DS1307_DAY_OF_WEEK_REG 3
#define DS1307_DATE_REG 4
#define DS1307_MONTH_REG 5
#define DS1307_YEAR_REG 6
#define DS1307_CONTROL_REG 7
#define DS1307_DATE_TIME_BYTE_COUNT 7 // Includes bytes 0-6
#define DS1307_NVRAM_START_ADDR 8
// We disable the SQWV output, because it uses
// a lot of battery current when it's enabled.
// Disable it by setting Out = Open Collector.
#define DS1307_CONTROL_REG_INIT_VALUE 0x80
char gca_ds1307_regs[DS1307_DATE_TIME_BYTE_COUNT];
void ds1307_set_date_time(void);
void ds1307_read_date_time(void);
char ds1307_read_byte(char addr);
char bcd2bin(char bcd_value);
char bin2bcd(char bin_value);
void ds1307_write_byte(char addr, char value);
char i;
// Convert the binary ds1307 data, which is passed in a global array,
// into bcd data. Store it in the same array.
for(i = 0; i < 7; i++)
gca_ds1307_regs[i] = bin2bcd(gca_ds1307_regs[i]);
// There are two control bits embedded in the following data.
// The Clock Halt bit is in bit 7 of the DS1307 Seconds register.
// We need to make sure that it's = 0, to make the clock run.
// The other bit is the 24/12 hour clock format bit, in bit 6 of
// the DS1307 Hours register. We need 24 hour mode, so set it = 0.
gca_ds1307_regs[DS1307_SECONDS_REG] &= 0x7f;
gca_ds1307_regs[DS1307_HOURS_REG] &= 0x3f;
// Now write the 7 bytes of BCD data to the ds1307,
// using inline code for speed.
disable_interrupts(GLOBAL);
i2c_start();
i2c_write(DS1307_I2C_WRITE_ADDR);
// Start reading at the Seconds register.
i2c_write(DS1307_SECONDS_REG);
// Write 7 bytes, to registers 0 to 6.
i2c_write(gca_ds1307_regs[i]);
// After setting the time in registers 0-6, also set the
// Control register. (index = 7)
// This just turns off the squarewave output pin.
// Doing it here, every time we set the clock registers,
// seems less risky than setting it near the
// start of the program, every time the unit powers-up.
i2c_write(DS1307_CONTROL_REG_INIT_VALUE);
i2c_stop();
// Read the date and time.
// The registers inside the ds1307 are in this order.
// The values inside the registers are in BCD.
// DS1307_SECONDS_REG_ADDR 0
// DS1307_MINUTES_REG_ADDR 1
// DS1307_HOURS_REG_ADDR 2
// DS1307_DAY_OF_WEEK_REG_ADDR 3
// DS1307_DATE_REG_ADDR 4
// DS1307_MONTH_REG_ADDR 5
// DS1307_YEAR_REG_ADDR 6
// We return the data in a global array. The data in is binary.
// seconds // 0-59 seconds
// minutes // 0-59 minutes
// hours // 0-23 hours
// day_of_week // 1-7
// date // 1-31 date
// month // 1-12 month
// year // 00-99 year (based on year 2000)
char i;
i2c_start();
i2c_start();
i2c_write(DS1307_I2C_READ_ADDR);
// Read the 7 bytes from the ds1307. Mask off the unused bits.
gca_ds1307_regs[DS1307_SECONDS_REG] = i2c_read() & 0x7f;
gca_ds1307_regs[DS1307_MINUTES_REG] = i2c_read() & 0x7f;
gca_ds1307_regs[DS1307_HOURS_REG] = i2c_read() & 0x3f;
gca_ds1307_regs[DS1307_DAY_OF_WEEK_REG] = i2c_read() & 0x07;
gca_ds1307_regs[DS1307_DATE_REG] = i2c_read() & 0x3f;
gca_ds1307_regs[DS1307_MONTH_REG] = i2c_read() & 0x1f;
gca_ds1307_regs[DS1307_YEAR_REG] = i2c_read(0);
i2c_stop();
// Now convert the data from BCD to binary.
// Do it after reading the bytes, so that
// the i2c reads can be done quickly.
gca_ds1307_regs[i] = bcd2bin(gca_ds1307_regs[i]);
// Read one byte at the specified address.
// This function is used to access the control byte
// or the NVRAM bytes.
char retval;
i2c_start();
i2c_write(addr);
i2c_start();
retval = i2c_read(0); // Don't ACK the last byte read
i2c_stop();
return(retval);
// Write one byte to the DS1307.
i2c_start();
i2c_write(addr);
i2c_write(value);
i2c_stop();
// This function converts an 8 bit binary value
// to an 8 bit BCD value.
// The input range must be from 0 to 99.
char bin2bcd(char binary_value)
char temp;
char retval;
temp = binary_value;
retval = 0;
// Get the tens digit by doing multiple subtraction
// of 10 from the binary value.
if(temp >= 10)
temp -= 10;
retval += 0x10;
else // Get the ones digit by adding the remainder.
retval += temp;
return(retval);
// This function converts an 8 bit BCD value to
// an 8 bit binary value.
// The input range must be from 00 to 99.
char temp;
temp = bcd_value;
// Shifting upper digit right by 1 is same as multiplying by 8.
temp >>= 1;
// Isolate the bits for the upper digit.
temp &= 0x78;
// Now return: (Tens * 8) + (Tens * 2) + Ones
return(temp + (temp >> 2) + (bcd_value & 0x0f));
and
//test.c
// DS1307 Driver file from PCM Programmer 18-11-03
// Version 1
#include <16F876.h>
// If your demo board is running at 4 MHz, then change
// the HS to be XT, in the line below.
#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT,NOLVP
// If you are using a 4 MHz crystal (or 20 MHz) then change
// the value in the next line, to match your crystal frequency.
//#use delay(clock=8000000)
// My test board uses pin B7 and B6, instead of C4 and C3, so
// I've changed the #use i2c statement to reflect that, below.
#use i2c(Master, SDA=PIN_B7, SCL=PIN_B6)
//#use i2c(Master, SDA=PIN_C4, SCL=PIN_C3)
#include <ds1307.c>
//#define DS1307_SECONDS_REG 0
//#define DS1307_MINUTES_REG 1
//#define DS1307_HOURS_REG 2
//#define DS1307_DAY_OF_WEEK_REG 3
//#define DS1307_DATE_REG 4
//#define DS1307_MONTH_REG 5
//#define DS1307_YEAR_REG 6
//#define DS1307_CONTROL_REG 7
//#define DS1307_DATE_TIME_BYTE_COUNT 7 // Includes bytes 0-6
//#define DS1307_NVRAM_START_ADDR 8
//#define DS1307_CONTROL_REG_INIT_VALUE 0x80
// 32.768 KHz output
//#define DS1307_CONTROL_REG_INIT_VALUE 0x13
// GLOBAL VARIABLES
// This is a global array to hold data which is passed to/from the
// functions that set the ds1307 date and time.
// FUNCTION PROTOTYPES
char bin2bcd(char binary_value);
main()
char sec;
char min;
char hrs;
char day;
char date;
char month;
char yr;
printf("Start\n\r");
// Put some date and time values into the global date & time array.
gca_ds1307_regs[DS1307_SECONDS_REG] = 0; // 0 seconds
gca_ds1307_regs[DS1307_MINUTES_REG] = 10; // 10 minutes
gca_ds1307_regs[DS1307_HOURS_REG] = 8; // 8 AM
gca_ds1307_regs[DS1307_DAY_OF_WEEK_REG]= 0; // Skip this.
gca_ds1307_regs[DS1307_DATE_REG] = 19; // 19th
gca_ds1307_regs[DS1307_MONTH_REG] = 4; // April
gca_ds1307_regs[DS1307_YEAR_REG] = 02; // 2002
// Write these values to the DS1307, for testing.
ds1307_set_date_time();
// Now read the date and time once every second, and display it.
ds1307_read_date_time();
// Get these into variables with shorter names, so I can
// put them into printf more easily.
sec = gca_ds1307_regs[DS1307_SECONDS_REG];
min = gca_ds1307_regs[DS1307_MINUTES_REG];
hrs = gca_ds1307_regs[DS1307_HOURS_REG];
day = gca_ds1307_regs[DS1307_DAY_OF_WEEK_REG];
date = gca_ds1307_regs[DS1307_DATE_REG];
month = gca_ds1307_regs[DS1307_MONTH_REG];
yr = gca_ds1307_regs[DS1307_YEAR_REG];
printf("\%d/\%d/\%02d \%d:\%d:\%02d\n\r",month,date,yr, hrs,min,sec);
Posted: Wed Jul 14, 2004 10:51 pm |
The first thing I have to ask, is do you have a 3v lithium battery
connected between the Vbat pin of the DS1307 and ground ? |
Posted: Wed Jul 14, 2004 11:01 pm |
I ran your code as-is on a 16F876A with DS1307 on rb0, and rb1, and it worked just fine. I suspect you have a problem with your crystal or connection. |
Tullos Guest
Posted: Wed Jul 14, 2004 11:13 pm |
I connected the battery line to +5v, is that my problem? |
Posted: Wed Jul 14, 2004 11:34 pm |
Quote: | I connected the battery line to +5v, is that my problem? |
The ds1307 data sheet says the recommend minimum voltage for the
Vbat pin is 2.0v, and the maximum is 3.5v.
http://pdfserv.maxim-ic.com/en/ds/DS1307.pdf |
Tullos Guest
Posted: Thu Jul 15, 2004 1:10 am |
perfect! |
cxiong
Posted: Thu Oct 21, 2004 11:00 am |
I use the above software for my ds1307 and I have constant display of
4/19/02 8:10:00
4/19/02 8:10:00
4/19/02 8:10:00
4/19/02 8:10:00
all the time, the time will not update at all.
Does it suppose to update the second, minute, hour etc?
I have 3.05V at Vbat.
What is wrong? |
cxiong
Mark
Posted: Thu Oct 21, 2004 11:50 am |
Try enabling the square wave output and look at the signal. This will verify the clock is working. |
asmallri
Posted: Thu Oct 21, 2004 12:01 pm |
I may have read the crystal spec wrong (sorry in advance if I have) but it looks to me like you have a 32MHz crystal instead of a 32KHz crystal. |
cxiong
Posted: Thu Oct 21, 2004 12:13 pm |
Yes, you right.
I have a 32.768Mhz instead of 32.768Khz.
Thanks.... |
DS1307 Sync to PC Clock |
Posted: Mon Jan 03, 2005 10:01 am |
How can I load the current time of the PC (set time clock from PC by serial) to the DS1307 instead of the following.
Code: | printf("Start\n\r");
Please advise.
Thanks |
Mark
Posted: Mon Jan 03, 2005 10:06 am |
Send the data from the PC to the PIC serially. Receive the data from the PC using the UART. Instead of using the hardcoded numbers, use the data received from the PC.
Now is that what you want to know or are you wanting someone to actually write the code for you? |
