for loop problem
future
for loop problem
PostPosted: Wed Oct 20, 2004 4:45 pm     Reply with quote
I am having this problem that I could not solve by myself.
This code searches through 4 bins to find where given value fits
and interpolates a result based on its findings.
For some reason itps gets a value of 3 when it should not.
Any hints?
Thank you.
//This interpolates between y1 and y2, result depends on where x
//fits between x1 and x2.
int8 interp(char x,char x1,char x2,char y1,char y2);
const char tpsdt[4]  = {0x05,  //  2 .
                        0x14,  //  4 ..
                        0x28,  //  8 ...
                        0x4D}; // 15 volts delta
for(itps=0;itps<3;itps++)                  // find bin position
   { if(tpsdot<tpsdt[itps+1]) { break; } } //
calc=interp(tpsdot,                        // interpolate result
            tpsdt[itps],                   //
            tpsdt[itps+1],                 //
            cfg.tps[itps],                 //
            cfg.tps[itps+1]);              //
Haplo
PostPosted: Wed Oct 20, 2004 5:23 pm     Reply with quote
You are checing the following condition for the itps values of 0, 1 and 2.
if (tpsdot<tpsdt[itps+1])
So basiaclly you are comparing tpsdot to numbers 0x05,0x14 and 0x28. Now lets say tpsdot assumes a value higher than 0x28 for whatever reason). The above condition will never become true so you will never break out of the for loop. itps will keep increasing until it reaches 3, then the condition inside the for loop (;itps<3;) will cause it to terminate. In this case at the next line itps will be equal to 3.
future
PostPosted: Wed Oct 20, 2004 5:47 pm     Reply with quote
So a simple
   for(itps=0;itps<[b]2[/b];itps++)
solves all my problems.
Thank you.
Haplo
PostPosted: Wed Oct 20, 2004 5:59 pm     Reply with quote
But aware that this is not good coding practice.
future
PostPosted: Wed Oct 20, 2004 6:13 pm     Reply with quote
Do you have any sugestions?
Haplo
PostPosted: Wed Oct 20, 2004 6:23 pm     Reply with quote
What is the maximum value tpsdot can have?
future
PostPosted: Wed Oct 20, 2004 6:47 pm     Reply with quote
I will use a maximum value of 77 (0x4D) but it 'can' go up to 255.
Haplo
PostPosted: Thu Oct 21, 2004 1:01 am     Reply with quote
Well since your for index can only be 0 and 1, you are not using half of the tpsdt[4] array.
And it is a good idea to put a safeguard there in case the value gets bigger than 0x4D. Something like:
if(itps<4)
            tpsdt[itps],                   //
            tpsdt[itps+1],                 //
            cfg.tps[itps],                 //
            cfg.tps[itps+1]);
    printf("some error message");
