Richard Guest
PIC18F6520 "Fast" Fast interrupt |
Posted: Wed Oct 20, 2004 7:19 am |
Folk,
I have been writing code using CCS 3.207 and was wondering if there was a way to reduce the interrupt latency of the external interrupt.
My interrupt routine is a trivial response to an external trigger, (clear a variable, clear timer1).
The code is short enough to actually fit in the memory at 0x0008-0x0018 although the compiler insists on locating it elsewhere and jumping there.
Is there any way I can encourage the compiler to squeze my ISR into this gap?
Org 0x0008, 0x0018 is apparently not a valid range.
On a related note, is there any method of optimizing out the majority of the completely unnecessary context saving that the compiler uses on a normal interrupt? (Other than a global interrupt handler)
Thanks for any assistance,
Richard, UK |
Posted: Wed Oct 20, 2004 7:47 am |
Quote: | Is there any way I can encourage the compiler to squeze my ISR into this gap?
Org 0x0008, 0x0018 is apparently not a valid range. |
Yes. You can fool the compiler into thinking the vectors will be elsewhere and then you have control of the original vectors
Code: | #build(interrupt=0x028)
#org 0x0020, 0x002f {}
/* Map the high priority interrupt vector */
#org 0x0008, 0x000f
void my_hp_intr (void)
#asm ASIS
// ... do your stuff here
retfie 1 //; fast return from interrupt
#endasm
/* Map the low priority interrupt vector */
#org 0x0018, 0x001f
void my_lp_intr (void)
#asm
goto 0x0200
#endasm
#org 0x0200, 0x5fff // or wherever
void LPIntrHdlr(void) {
// etc etc etc |
Richard Guest
Faster interrupt |
Posted: Wed Oct 20, 2004 9:11 am |
Thanks for your suggestion I carried out the following:
#org 0x0008, 0x0014
void Fake_ISR() {
// This is really the fast interrupt
// External interrupt
#asm
CLRF 0xFCF // clear Timer1H
CLRF 0xFCE // clear Timer1L
CLRF 0x39 // clear CounterH
CLRF 0x38 // clear CounterL
BCF 0xFF2.1 //clear interrupt flag
RETFIE 1
#endasm
#org default
This carried out the ISR as expected. I also need to map my Counter variable so that it doesn't move about if I change my variables ;-)
This produced the following list snipppet
org 0x0008, 0x0014
.................... void Fake_ISR() {
.................... // This is really the fast interrupt
.................... // External interrupt
.................... #asm
.................... CLRF 0xFCF // clear CounterH
0008: CLRF FCF
.................... CLRF 0xFCE // clear CounterL
000A: CLRF FCE
.................... CLRF 0x39 // clear CounterH
000C: CLRF 39
.................... CLRF 0x38 // clear CounterL
000E: CLRF 38
.................... BCF 0xFF2.1 //clear interrupt flag
0010: BCF FF2.1
.................... RETFIE 1
0012: RETFIE 1
.................... #endasm
0014: RETLW 00
.................... #org default |
ie It did exactly what was wanted (except for the spare RETLW 00 from the closing brace of the void function, which never gets called).
My original mistake was to try and #ORG the CCS #int_ext ISR.
Thanks for your help!
Richard |
asmallri
Joined: 12 Aug 2004 Posts: 1635 Location: Perth, Australia
Posted: Wed Oct 20, 2004 10:49 am |
No problem.
Don't forget you can use your C labels in assembler
byte CounterH; #locate Rx_HeadL = 0x40
byte CounterL; #locate Rx_HeadL = 0x41 |
then your code becomes..
Code: | #org 0x0008, 0x0014
void Fake_ISR() {
#asm
CLRF CounterH // clear CounterH
CLRF CounterL // clear CounterL
RETFIE 1
#endasm
Remember to keep you variables below 0x80 to save having to use the BSR
[/code] |
