Selecting Vref on PIC12F675
John Morley
PostPosted: Tue Oct 19, 2004 11:26 am     Reply with quote
Hi All,
I am trying to use analog inputs AN0 and AN2 on a PIC12F675 device. I also want to use a voltage reference connected to the Vref input. The header file for this device says that I can OR constants used with the SETUP_ADC_PORTS function, but this does not seem to be working correctly. Both analog inputs are working properly, but the problem is that the PIC seems to be using Vdd (+5V) for Vref instead of my 2.5V reference. Here is the new constant I created in the header file:
#define AN0_AN2_VREF          0x4007    //| GP0 GP2 Vref
Here is the original header file:
// Constants used in SETUP_ADC_PORTS() are: (These may be ORed together)
#define NO_ANALOGS             0
#define ALL_ANALOG             15        //| GP0 GP1 GP2 GP4
#define AN0_ANALOG             1         //| GP0
#define AN1_ANALOG             2         //| GP1
#define AN2_ANALOG             4         //| GP2
#define AN3_ANALOG             8         //| GP4
#define VREF                  0x4002
#define VSS_VDD               0x0000
#define VSS_VREF              0x4002     //| Range 0-Vref
The .lst output seems to be setting the correct bit in the ADCON0 register to select Vref, so I'm not sure where to look next. Any ideas?
Thanks!
John Morley
PostPosted: Tue Oct 19, 2004 11:39 am     Reply with quote
Post the exact line of code that you're trying to use with the
setup_adc_ports() function, and post the version of your compiler.
John Morley
PostPosted: Tue Oct 19, 2004 12:36 pm     Reply with quote
Hi PCM,
Sorry, I should have included that information the first time! My compiler (PCM) is version 3.162. Here is the code that sets up and reads the analog inputs:
      setup_adc_ports(AN0_AN2_VREF);
      setup_adc(ADC_CLOCK_INTERNAL );
      set_adc_channel(Temp_Input);
      delay_ms(150);                     // Allow the channel to be aquired
      TValue=read_adc();
      delay_ms(10);                      // delay for the reading to be taken
      set_adc_channel(Voltage_Input);
      VValue=read_adc();
Thanks!
John Morley
PostPosted: Tue Oct 19, 2004 1:22 pm     Reply with quote
There appears to be a mistake in the 12F675.H file for PCM vs. 3.162.
The following two lines are wrong.
#define VREF                  0x4002
They should be:
#define VREF                  0x4000
#define VSS_VREF              0x4000     //| Range 0-Vref
