How to define a bit from an address
alexz
PostPosted: Fri Oct 15, 2004 6:19 am     Reply with quote
I have got a register at the particular address in another device.
Say #define ADDR 0x01
I want to work with separe bits, of this register, which is at ADDR address from the PIC.
What is the way to define a bit from this register?
Alex
Haplo
PostPosted: Fri Oct 15, 2004 6:50 am     Reply with quote
What do you mean by 'Another device'?
This post shows how to use #byte/#bit:
http://www.ccsinfo.com/forum/viewtopic.php?p=33797&highlight=#33797
alexz
PostPosted: Fri Oct 15, 2004 6:53 am     Reply with quote
Another device ,means USBN9603, which has its own registers, and I have to WR/RD to/from them.
And I also need to work with its separate bits of each register.
Alex
Mark
PostPosted: Fri Oct 15, 2004 8:01 am     Reply with quote
There are lots of ways to do it, structs, unions...but probably the best way for you would be to just read the value and then use
bit_set()
bit_clear()
bit_test()
functions on it.
rnielsen
PostPosted: Fri Oct 15, 2004 8:14 am     Reply with quote
First, define the byte:
#byte SSPCON = 0x14
Then, define the individual bits inside that byte:
//SSPCON bits
#bit SSPM0 = SSPCON.0
#bit SSPM1 = SSPCON.1
#bit SSPM2 = SSPCON.2
#bit SSPM3 = SSPCON.3
#bit CKP = SSPCON.4
#bit SSPEN = SSPCON.5
#bit SSPOV = SSPCON.6
#bit WCOL = SSPCON.7
Now, you can simply manipulate those bits...
if(CKP)
do this;
or....
CKP = 0;
and so forth.
Ronald
alexz
PostPosted: Fri Oct 15, 2004 8:25 am     Reply with quote
#byte SSPCON = 0x14
//SSPCON bits
#bit CKP = SSPCON.4
if(CKP)
do this;
or....
CKP = 0;
and so forth.
Ronald
It is very close to what I need, but what is the way to be able to have those bits in the following way:
if(SSPCONbits.CKP)
do this;
How can I define those bits to get them look like on the above?
Alex
alexz
PostPosted: Fri Oct 15, 2004 9:02 am     Reply with quote
Basically,the story is that I have an external device to be controled by the PIC. I have to access this device's registers by bits.
I am writing first the address of the register, I am going to work with,
a pointer if you like,
then I need to set or clear bits in this register.
How to do that?
Alex
PostPosted: Fri Oct 15, 2004 9:59 am     Reply with quote
If you have the CCS compiler, and you got it any time in the last
several months, then you already have a driver for the usbn960x
chips on your system.
It's called: USBN960x.C
It will be in this folder: c:\Program Files\Picc\Drivers.
(In fact, look at all the files in that folder that start with "usb").
To see how the driver reads and writes to registers in the USB chip,
look at these functions:
usbn_write()
usbn_read()
Look at how those functions toggle the control signals on the USBN960x
chip. Look at the USBN960x data sheet while you're doing this.
This will show you how the interface works.
