Question about UART transmission
YulL
PostPosted: Wed Oct 13, 2004 3:09 am     Reply with quote
Hi everybody!
I have a simple question regards the UART interface with CCS Compiler : is it possible to send a simple byte like 0x2C on the serial port, which is not an ASCII character ?
Rolling Eyes
Thanks for your support
dvsoft
PostPosted: Wed Oct 13, 2004 3:41 am     Reply with quote
bonjour
yes completely why?
Alain
YulL
PostPosted: Wed Oct 13, 2004 3:52 am     Reply with quote
Coucou Surprised
Ok I have to send 0x0001C8C8 to a module with USART interface, but I'm not sure that my program will work, I'm going to test it in a few days.
Here is my code :
while(getc()!=0x10) {} // Attente du "Frame Char" pour se synchroniser
printf(lcd_putc,"\fSynchro OK!\n");
trame=getc(); // Lecture de la suite
if(trame=0x0001C8C8) output_high(LED0);
Thanks for the reply Wink
PostPosted: Wed Oct 13, 2004 4:07 am     Reply with quote
YulL wrote:
Coucou Surprised
Here is my code :
A _byte_. only holds 8bts of data. The serial link transfers data a byte at a time. What you need is something like:
union dblock {
    int32 word;
    int8 b[4];
} buffer;
int 8 count;
   while(getc()!=0x10);// Attente du "Frame Char" pour se synchroniser
   for (count=0;count<4;count++) {
      buffer.b[count]=getc();           // Lecture de la suite
   if(buffer.word=0x0001C8C8L)
       output_high(LED0);[/color]
You will have to check whether the data is send least significant byte first or last, and change the count to correspond. This reads the four successive bytes, into b[0]...b[4], and then performs a test with the resulting 32bit 'word'.
YulL
PostPosted: Wed Oct 13, 2004 4:27 am     Reply with quote
Thanks for your help! Cool
I will try it in a few days (I haven't the possibility to test it yet).
it is "if(buffer.word=0x0001C8C8) output_high(LED0);" and not "if(buffer.word=0x0001C8C8L) output_high(LED0);" ?
Wink
dvsoft
PostPosted: Wed Oct 13, 2004 8:24 am     Reply with quote
bonjour,
ATTENTION
in C language the test operator is "=="
if (testValue == 0x0001C8C8)
output_high(LED0);
Alain
YulL
PostPosted: Wed Oct 13, 2004 8:40 am     Reply with quote
Thanks Alain, have a nice evening Wink
PostPosted: Wed Oct 13, 2004 10:48 am     Reply with quote
Wink
'L', means force use of a 'long'. Though the compiler _should_ automatically detect that something 'larger' than 0xFF, needs a long comparison, I never trust it, and will always explicitly declare anything larger than 8bit, as a long.
