Help for rf12F675H
ikague
Help for rf12F675H
PostPosted: Tue Oct 12, 2004 11:47 pm     Reply with quote
Hi all
I have wroten this Code for the rf12F675H . But nothing happens.
#include "12f675.h"
#case
#fuses hs,noprotect,nobrownout,put,nowdt
      output_high(PIN_A0);
      output_high(PIN_A1);
      output_high(PIN_A2);
      output_high(PIN_A3);
      output_high(PIN_A4);
      output_high(PIN_A5);
      output_low(PIN_A0);
      output_low(PIN_A1);
      output_low(PIN_A2);
      output_low(PIN_A3);
      output_low(PIN_A4);
      output_low(PIN_A5);
Do someone see an Error ???
Ikague
PostPosted: Wed Oct 13, 2004 12:57 am     Reply with quote
Hi
I forgot. I use the internal oscillator.
kypec
PostPosted: Wed Oct 13, 2004 1:29 am     Reply with quote
I'm not sure whether the compiler configures
all the port pins which share the A/D feature
automatically as DIGITAL I/O or not.
I wouldn't rely on it and better have done it
myself:
setup_adc_ports(NO_ANALOGS)
Same applies to Analog comparators:
setup_comparators(NC_NC_NC_NC)
For further details please look in your
PICC\Devices\12F675.h header file
dvsoft
PostPosted: Wed Oct 13, 2004 2:08 am     Reply with quote
bonjour,
#include <12F675H.h>
#device adc=8
#fuses NOWDT,INTRC, NOCPD, NOPROTECT, MCLR, NOPUT, BROWNOUT
   setup_adc(ADC_OFF);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
try this code setup
Alain
languer
PostPosted: Wed Oct 13, 2004 1:21 pm     Reply with quote
Ikague,
You are currently using this:
#include "12f675.h"
#case
You want to change it to this (so you use the internal oscillator):
#include "12f675.h"
#device ADC=10
#case
#fuses intrc_io,noprotect,nobrownout,put,nowdt,nocpd,nomclr
The #fuses command is the source of your problems. You did not define the intrc_io (enables internal oscillator, and IO function on GP4 and GP5), you used hs instead (for external high-speed oscillator). You also did not define nomclr to free GP3 (for input only)
Disable comparators and ADC function (as suggested previously):
setup_comparator( NC_NC_NC_NC );   // disable comparators
setup_adc_ports( NO_ANALOGS );   // disable analog inputs
setup_adc( ADC_OFF );         // disable A2D
And eliminate:
and
output_low(PIN_A3);
since you can only use this pin as an input.
Hope this helps.
PostPosted: Wed Oct 13, 2004 1:37 pm     Reply with quote
I think you are using PCM vs. 3.099. If so, the functions shown
above do not work properly for the 12F675.
To fix the problem, you need to directly set the register values
for the comparators and the ADC. Look at the highlighted lines
in following link. You need to add those six lines of code to your
program, in the same positions as shown in this link.
http://www.ccsinfo.com/forum/viewtopic.php?t=2808&highlight=cmcon+adcon0+ansel
ikague
It works!!!!!
PostPosted: Wed Oct 13, 2004 9:48 pm     Reply with quote
Thanks All. It works now !!!!!!! Very Happy
