poorly Guest
compiling problem |
Posted: Wed Sep 29, 2004 7:17 am |
15:59 29.09.2004
dear friends
If I use MPLAB IDE ver:6.61 for the code below (LCD.C included ), I get an error.
but compiling with the MPLAB ver: 5.70 , no error & problem.
Everything goes fine...
What should I do to use MPLAB IDE ver:6.61 with no error !
thanks interested guys a lot for proper reply.
poorly
Here are a few lines of the code. and the include file. (LCD.C)
#include <16f877.h>
#include <stdio.h>
#include <F877.h>
#fuses HS,NOWDT,NOPROTECT, NOBROWNOUT, NOLVP, PUT
#include "lcd.c"
main()
int value_o=0;
for(;;){
printf(lcd_putc, "\fValue:%d" ,value_o);
value_o+=1;
LCD.C code :
//// LCDD.C ////
//// Driver for common LCD modules ////
//// lcd_init() Must be called before any other function. ////
//// lcd_putc(c) Will display c on the next position of the LCD. ////
//// The following have special meaning: ////
//// \f Clear display ////
//// \n Go to start of second line ////
//// \b Move back one position ////
//// lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1) ////
//// lcd_getc(x,y) Returns character at position x,y on LCD ////
//// (C) Copyright 1996,1997 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS C ////
//// compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, reproduction ////
//// or distribution is permitted without written permission. ////
//// Derivative programs created using this software in object code ////
//// form are not restricted in any way. ////
// As defined in the following structure the pin connection is as follows:
// D0 enable
// D1 rs
// D2 rw
// D4 D4
// D5 D5
// D6 D6
// D7 D7
// LCD pins D0-D3 are not used and PIC D3 is not used.
// Un-comment the following define to use port B
// #define use_portb_lcd TRUE
struct lcd_pin_map { // This structure is overlayed
boolean enable; // on to an I/O port to gain
boolean rs; // access to the LCD pins.
boolean rw; // The bits are allocated from
boolean unused; // low order up. ENABLE will
int data : 4; // be pin B0.
} lcd;
#if defined(__PCH__)
#if defined use_portb_lcd
#byte lcd = 0xF81 // This puts the entire structure
#else
#byte lcd = 0xF83 // This puts the entire structure
#endif
#else
#byte lcd = 6 // on to port B (at address 6)
#else
#byte lcd = 8 // on to port D (at address 8)
#endif
#endif
#define set_tris_lcd(x) set_tris_b(x)
#else
#define set_tris_lcd(x) set_tris_d(x)
#endif
#define lcd_type 2 // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40 // LCD RAM address for the second line
byte CONST LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
// These bytes need to be sent to the LCD
// to start it up.
// The following are used for setting
// the I/O port direction register.
STRUCT lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
STRUCT lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
byte lcd_read_byte() {
byte low,high;
set_tris_lcd(LCD_READ);
lcd.rw = 1;
delay_cycles(1);
lcd.enable = 1;
delay_cycles(1);
high = lcd.data;
lcd.enable = 0;
delay_cycles(1);
lcd.enable = 1;
delay_us(1);
low = lcd.data;
lcd.enable = 0;
set_tris_lcd(LCD_WRITE);
return( (high<<4) | low);
void lcd_send_nibble( byte n ) {
lcd.data = n;
delay_cycles(1);
lcd.enable = 1;
delay_us(2);
lcd.enable = 0;
void lcd_send_byte( byte address, byte n ) {
lcd.rs = 0;
while ( bit_test(lcd_read_byte(),7) ) ;
lcd.rs = address;
delay_cycles(1);
lcd.rw = 0;
delay_cycles(1);
lcd.enable = 0;
lcd_send_nibble(n >> 4);
lcd_send_nibble(n & 0xf);
void lcd_init() {
byte i;
lcd.rs = 0;
lcd.rw = 0;
lcd.enable = 0;
delay_ms(15);
for(i=1;i<=3;++i) {
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0;i<=3;++i)
lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( byte x, byte y) {
byte address;
if(y!=1)
address=lcd_line_two;
address=0;
address+=x-1;
lcd_send_byte(0,0x80|address);
void lcd_putc( char c) {
switch (c) {
case '\f' : lcd_send_byte(0,1);
delay_ms(2);
case '\n' : lcd_gotoxy(1,2); break;
case '\b' : lcd_send_byte(0,0x10); break;
default : lcd_send_byte(1,c); break;
char lcd_getc( byte x, byte y) {
char value;
lcd_gotoxy(x,y);
while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
lcd.rs=1;
value = lcd_read_byte();
lcd.rs=0;
return(value);
Posted: Wed Sep 29, 2004 12:15 pm |
Quote: | If I use MPLAB IDE ver:6.61 for the code below (LCD.C included ), I get an error. |
Well, what error do you get ? |
Mark
Posted: Wed Sep 29, 2004 2:17 pm |
My guess is that the compiler is not set up properly. Did you install the plug in (it might be included in the later MPLAB). There are 2 choices for the compiler. Choose the one that lists the devices. |
poorly Guest
Mplab install error |
Posted: Fri Oct 08, 2004 3:09 am |
dear Mark
I found only one plug-in file on the CCS site.
What is the other one that you mentioned ?
I use the plug in for MPLAB 6 installation.
thanks a lot
poorly |
Mark
Posted: Fri Oct 08, 2004 9:01 am |
There is only 1 plug in. However, when you choose the tool suite there are 2 CCS options.
Someone asked what error. It is kind of hard to tell you what the problem might be without you telling us the error! |
poorly Guest
Posted: Mon Oct 11, 2004 3:45 am |
MArk
thank you for your kind reply
sincerely |
