mvaraujo
I2C slave address - Choosing address for a slave |
Posted: Tue Oct 05, 2004 10:49 am |
Hi!
How do you guys choose addresses for your I2C slave devices?
I have a situation that I'm communicating some different circuit boards using I2C (they are different PWBs but, they are inside the same product). There's only one master and the others are slaves. I can have a situation where memory IC or RTC will be populated on the master device board, but there's no other situation that I'll need to hang I2C application boards or ICs on the bus.
The answer could be: just choose any one! But I would like to read how you handle these issues!
Thanks,
Marcus Araujo
Brazil |
rnielsen
mvaraujo
Posted: Tue Oct 05, 2004 11:01 am |
Ronald,
That's exactly what I did before! Considering that few ranges that are reserved (0000xx, 1111xxxx, etc) you would take any number, right?
I understand the issue involving the R/W LSB bit, thanks!
Marcus |
rnielsen
Posted: Tue Oct 05, 2004 12:24 pm |
Looking at the address table, you could assign an address between 0x08 - 0xF6. If you have any other I2C devices in your design you might want to assign an address close to it's address but anything should work.
Ronald |
