cfernandez
Simulate a Keyboard and Send Character to PC |
Posted: Fri Oct 01, 2004 10:11 pm |
I need to send character to PS2 PC, simulating a Keyboard. I have a card reader and want to send some byte to PC by PS2 Keyboard. My project is the same that a Bar Code Reader that send the data by keyboard to PC. Exist any person that can help me or have this routine.
Thank you very much!!
Best Regards, |
Humberto
Posted: Sat Oct 02, 2004 5:49 am |
Hi Carlos,
Following you will find the full set of PS2 scancodes. All you need is to reproduce and transmit
the corresponding code accordingly with itīs function. Take in mind that it is mandatory to generate
and transmit a code when a key is pressed and another code when the key was released.
US 104-key keyboard, scancodes for PS2
"Make" code is generated when key is pressed.
"Break" code is generated when key is released.
Hex value of make code for each key is shown.
All keys:
one-byte make code = nn
one-byte repeat code = nn
two-byte break code = F0nn
____ ___________________ ___________________ ___________________
|Esc | |F1 |F2 |F3 |F4 | |F5 |F6 |F7 |F8 | |F9 |F10 |F11 |F12 |
| 08| | 07| 0F| 17| 1F| | 27| 2F| 37| 3F| | 47| 4F| 56| 5E|
|____| |____|____|____|____| |____|____|____|____| |____|____|____|____|
__________________________________________________________________________
|~ |! |@ |# |$ |% |^ |& |* |( |) |_ |+ || |bksp|
|` |1 |2 |3 |4 |5 |6 |7 |8 |9 |0 |- |= |\ | |
| 0E| 16| 1E| 26| 25| 2E| 36| 3D| 3E| 46| 45| 4E| 55| 5C| 66|
|____|____|____|____|____|____|____|____|____|____|____|____|____|____|____|
|Tab |Q |W |E |R |T |Y |U |I |O |P |{ |} | |
| 0D| 15| 1D| 24| 2D| 2C| 35| 3C| 43| 44| 4D| 54| 5B| |
|____|____|____|____|____|____|____|____|____|____|____|____|____| |
|Caps|A |S |D |F |G |H |J |K |L |: |" | Enter |
| 14| 1C| 1B| 23| 2B| 34| 33| 3B| 42| 4B| 4C| 52| 5A|
|____|____|____|____|____|____|____|____|____|____|____|____|______________|
| L Shift |Z |X |C |V |B |N |M |< |> |? | R Shift |
| 12| 1A| 22| 21| 2A| 32| 31| 3A| 41| 49| 4A| 59|
|_________|____|____|____|____|____|____|____|____|____|____|______________|
|L Ctrl | L win | L Alt | space | R Alt | R win | menu |R Ctrl |
| 11| 8B| 19| 29| 39| 8C| 8D| 58|
|_______|_______|_______|__________________|_______|_______|_______|_______|
____ ____ ____
|Prt |Scrl|Paus|
|Scrn|Lock|Brk |
| 57| 5F| 62|
|____|____|____|
____ ____ ____ ____ ____ ____ ____
|Ins |Home|PgUp| |Num |/ |* |- |
| | | | |Lock| | | |
| 67| 6E| 6F| | 76| 77| 7E| 84|
|Del |End |PgDn| |7 |8 |9 | |
| | | | |Home|(U) |PgUp| |
| 64| 65| 6D| | 6C| 75| 7D| |
|____|____|____| |____|____|____| |
|4 |5 |6 | |
|(L) | |(R) | |
| 6B| 73| 74| 7C|
____ |____|____|____|____|
|(U) | |1 |2 |3 | |
| | |End |(D) |PgDn| |
| 63| | 69| 72| 7A|Ent |
____|____|____ |____|____|____| |
|(L) |(D) |(R) | |0 |. | |
| | | | |Ins |Del | |
| 61| 60| 6A| | 70| 71| 79|
|____|____|____| |_________|____|____|
code key code key code key code key
07 F1 2A V 4A /? 6B (left) 4
08 Esc 2B F 4B L 6C Home 7
2C T 4C ;: 6D PageDown
0D Tab 2D R 4D P 6E Home
0E `~ 2E 5% 4E -_ 6F PageUp
0F F2 2F F6 4F F10 70 Ins 0
71 Del .
11 L Ctrl 31 N 52 '" 72 (down) 2
12 L Shift 32 B 73 5
33 H 54 [{ 74 (right) 6
14 CapsLock 34 G 55 =+ 75 (up) 8
15 Q 35 Y 56 F11 76 NumLock
16 1! 36 6^ 57 PrintScr 77 /
17 F3 37 F7 58 R Ctrl
59 R Shift 79 Enter (on numeric keypad)
19 L Alt 39 R Alt 5A Enter 7A PageDown 3
1A Z 3A M 5B ]}
1B S 3B J 5C \| 7C +
1C A 3C U 7D PageUp 9
1D W 3D 7& 5E F12 7E *
1E 2@ 3E 8* 5F ScrollLock
1F F4 3F F8 60 (down) 84 -
61 (left)
21 C 41 ,< 62 Pause 8B L Win
22 X 42 K 63 (up) 8C R Win
23 D 43 I 64 Del 8D Menu
24 E 44 O 65 End
25 4$ 45 0) 66 BackSpace
26 3# 46 9( 67 Ins
27 F5 47 F9
69 End 1
29 Space 49 .> 6A (right)
Best wishes,
Humberto |
cfernandez
Posted: Sat Oct 02, 2004 9:39 am |
Humberto,
Vos tenes alguna rutina en C para poder conectar un PIC al puerto PS2 PC y enviar caracteres como si fuera el teclado?. Es mas este PIC debe estar entre el teclado y la PC, imaginate un lector de codigo de barras o banda magnetica que se conecta asi y le mandan los caracteres a la PC que obtienen de su lectura.
Espero que puedas ayudarme, muchas gracias. |
Humberto
Posted: Sat Oct 02, 2004 11:19 am |
I will contact you in your private mssge box,
Regards
Humberto |
Mark
Posted: Sat Oct 02, 2004 11:44 am |
Quote: |
Humberto,
Roughly translated:
Do you have some routines in C to be able to connect a PIC to a PC's PS2 port and send characters as though it was a keyboard? This PIC should go between the keyboard and the PC. Imagine a bar code or magnetic stripe reader that will send the characters to the PC from the data that it obtains from its reading.
I expect that you can help me, many thanks.
Check this link out:
http://panda.cs.ndsu.nodak.edu/~achapwes/PICmicro/PS2/ps2.htm |
Humberto
Posted: Sat Oct 02, 2004 12:17 pm |
Mark,
You are very kindly for translate this thread. As you can guess, Spanish is my natural language
but I make the effort to try to communicate in English because I don't want to betray the spirit of
this board which is to share our knowledge and experiences in a common language.
Anyway I just send a private message to cfernandez regarding the thread.
Thanks again and people like you are the responsible that made of this board one of the
most genuine discussion of embedded C systems.
Humberto  |
Mark
Posted: Sat Oct 02, 2004 2:12 pm |
I understand the reason that some post in their native language. However, they will get the most responses if they post it in the language that most of the posters understand. Thanks for the praise. |
jelodavid
Joined: 03 Apr 2005 Posts: 22 Location: Laguna Philippines
Posted: Tue May 19, 2009 6:15 pm |
Hello everybody,
I also need this code for my project. But i'm a bit confused about sending characters from PIC to PC. Maybe a sample code from you guys will help me a lot..pls |
