special wiring for RS485?
Einly
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger ICQ Number
PostPosted: Fri Oct 01, 2004 3:15 am     Reply with quote
Hi, I found a Shimaden temperature controller that only
using 2 wires +, - to connect to a RS485 to RS232
converter and then link to PC for cotrol purpose.
The system can read and write signal to/from the controller.
So, I just dubt why it doesn't use GND line also can work.
Thanks...
Einly,
Einly
Mark
PostPosted: Fri Oct 01, 2004 5:57 am     Reply with quote
RS485 uses differential voltage. That means that it subtracts the voltage between the two lines to get the data. Therefore there is no need for the ground which would be your reference voltage.
