Cannot multiply a 16-bit by an 8-bit to get a 32-bit ?
John_Lintern
PostPosted: Thu Sep 30, 2004 3:01 am     Reply with quote
I am using CCS PCW C Compiler in conjunction with MPLAB IDE to write a program for a PIC16C74B.
But I am having a problem multiplying 2 numbers together !
The result needs to be a 32-bit value and has to multiply a 16-bit value by an 8-bit value.
Take for example,
0x1234 * 0xA0 = 0x000B6080
(16bit) * (8bit) = (32bit)
But when I run the program the result gets truncated to a 16-bit value ??
So instead of getting 0x000B6080 I get 0x00006080
BUT..... if I declare ALL the variables as a 32-bit value it works !
This is ineffecient though because it uses up more memory - surely this can't be right ?
You should be able to multiply a 16-bit value by an 8-bit value to get a 32-bit value - shouldn't you ?
Below are the relevant pieces of code for my function 'Multiply':
unsigned int32 result=0x00000000; // 32-bit variable called result
unsigned int32 Multiply(unsigned int16,unsigned int8); //Multiply function
unsigned long A=0x1234; // 16-bit variable
unsigned int B=0xA0; // 8-bit variable
void(main)
result=Multiply(A,B);
while (TRUE)
// Multiply function
unsigned int32 Multiply(unsigned int16 X,unsigned int8 Y)
return(X * Y);
kypec
Use type casting
PostPosted: Thu Sep 30, 2004 4:17 am     Reply with quote
try this inside your function:
return (int32)x*y
Kieran
PostPosted: Thu Sep 30, 2004 5:59 am     Reply with quote
I would cast both first then multiply
return (int32) x * (int32) y;
Mark
PostPosted: Thu Sep 30, 2004 6:18 am     Reply with quote
That requires a 32b * 32b multiply which is what the poster did not wish.
John_Lintern
Re: Use type casting
PostPosted: Thu Sep 30, 2004 7:23 am     Reply with quote
return (int32)x*y
Thanks kypec !!!
That worked..... but I don't understand why ???
Why do you have to specify the return value as an int32 as you suggested ?
i.e. return (int32)X*Y
I thought the return value is specified as a 32-bit value in the lines....
here
and...
here
So why didn't....
return (X*Y)
work then ?
Mark
PostPosted: Thu Sep 30, 2004 7:28 am     Reply with quote
It actually casts the 'x' to a 32 bit and then multiplies it. That is why it works. (int32)(x*y) would cast the result. However, you would still get the truncated result by just casting the result.
