arya
write_program_memory / write_program_eeprom woes |
Posted: Wed Sep 22, 2004 2:17 pm |
I know this is similar to a lot of other posts, but I haven't been able to find an answer in the forum yet. I'm trying to write program memory on a 16F87, with the eventual goal of writing a bootloader-type thing. I'm using PCM 3.186.
I'm experimenting by trying to copy one instruction or so from one code block, and write it to an arbitrary location as a test. I think I've got my fuses set correctly, but it's not working.
Code: | //Configuration Fuses:
// Word 1: 2F38 NOWDT NOPUT MCLR NOBROWNOUT NOLVP NOCPD NOWRT NODEBUG CCPB3 NOPROTECT INTRC_IO
unsigned int16 i,j;
i = read_program_eeprom(0x40b);
// works fine, i == 0x130D (bcf 0xd, 0x6)
write_program_eeprom(0x690, i);
// doesn't seem to do anything
j = read_program_eeprom(0x690);
// j == 0x3FFF, default
write_program_memory(0x690, &i, 2);
// never returns
I've tried wrapping the calls inside
Code: | DISABLE_INTERRUPTS(GLOBAL);
ENABLE_INTERRUPTS(GLOBAL);
| like I'd seen suggested in some posts, but it didn't seem to have any effect.
Can anyone see what I'm doing wrong?
Thanks,
Arya |
arya
Posted: Mon Sep 27, 2004 2:37 pm |
Alright, nevermind, NOLVP was the problem. |
arya
Posted: Wed Sep 29, 2004 7:26 pm |
I take it back! LVP doesn't seem to be related.
It works intermittently, mostly not, but every few resets, so.
erase_program_eeprom() always seems to work, but neither write_program_eeprom(addr, inst) nor my own write routine (below) work reliably. About 2% of the time, they do work. And then I'm terribly confused. Hard resets between retries.
Help! (I would rather use compiler built-ins).
struct {
int rd : 1;
int wr : 1;
int wren : 1;
int wrerr : 1;
int free : 1;
int unused1 : 2;
int eepgd : 1;
} EECON1_S;
#byte EEDATA = 0x10c
#byte EEADR = 0x10d
#byte EEDATH = 0x10e
#byte EEADRH = 0x10f
#byte EECON1_S = 0x18c
#byte EECON2 = 0x18d
// this function's supposed to write to program memory 0x690 - 0x693
// erase_program_eeprom(0x680) has already been called,
// which clears 0x680 - 0x6bff
// loop has been unrolled, out of desperation
// interrupts are disabled!
void write_routine2() {
EECON1_S.eepgd = 1;
EECON1_S.wren = 1;
EEADRH = 0x06;
EEADR = 0x90;
EEDATA = 0x01;
EEDATH = 0x23;
EECON2 = 0x55;
EECON2 = 0xAA;
EECON1_s.wr = 1;
#asm
nop
nop
#endasm
EEADR = 0x91;
EEDATA = 0x45;
EEDATH = 0x67;
EECON2 = 0x55;
EECON2 = 0xAA;
EECON1_s.wr = 1;
#asm
nop
nop
#endasm
EEADR = 0x92;
EEDATA = 0x89;
EEDATH = 0xab;
EECON2 = 0x55;
EECON2 = 0xAA;
EECON1_s.wr = 1;
#asm
nop
nop
#endasm
EEADR = 0x93;
EEDATA = 0xcd;
EEDATH = 0xef;
EECON2 = 0x55;
EECON2 = 0xAA;
EECON1_s.wr = 1;
#asm
nop
nop
#endasm
asmallri
Posted: Thu Sep 30, 2004 12:21 am |
There are some things better left to assembler
You forgot the delay for write completion or alternatively, check the previous write has completed before the next write.
Code: | bsf EECON1,EEPGD ; Point to program memory
bsf EECON1,WREN ; enable write operation
; force global interrupts to be disabled
WWEE1 bcf Intcon,GIE ; disable global interrupts
btfsc Intcon,GIE ; are global interrupts disabld?
goto WWEE1 ; No - try again
movlw 0x55
movwf EECON2 ; write control sequence
movlw 0xAA
bsf EECON1,WR ; write the data
bsf Intcon,GIE ; enable global interrupts
WaitWR
; Clrwdt
btfsc EECON1,WR ; wait for write to finish
goto WaitWR |
Trampas
Posted: Thu Sep 30, 2004 6:57 am |
I have been fighting the same monster. Except I have been bitten in the butt so many times using CCS intrensic functions like the read/write program memory functions. That I decided to start writting my own functions. So here is a link to some code to use to write your own read/writes... http://forum.microchip.com/m.asp?m=55318
Don't forget that the program memory is written 8 bytes at a time. That is if you have to write 8 bytes before the first gets written.
Trampas |
