rs232 problems Guest
rs232 problems |
Posted: Wed Sep 29, 2004 12:17 pm |
I wrote a small application to read from a GPS module and send whatever it reads to the PC.
Code: | #include <16f876.h>
#include <string.h>
#fuses XT, NOPROTECT, BROWNOUT, LVP, NOWDT, PUT
#use delay (clock=4000000)
#use rs232(baud=2400,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=GSM)
#use rs232(baud=4800,parity=N,xmit=PIN_C4,rcv=PIN_C5,bits=8,stream=HOSTPC)
#use rs232(baud=4800,parity=N,xmit=PIN_C2,rcv=PIN_C3,bits=8,stream=GPS)
fprintf(HOSTPC,"Ready");
c = fgetc(GPS);
fputc(c,HOSTPC);
When I run that program "Ready" is displayed correctly on my terminal. When the GPS unit starts to send the NMEA data I start to see garbage on my terminal except for the '$' and ',' characters. Both are displayed correctly and other characters are nothing but garbage.
I connected the GPS unit directly to my PC using max232 and it dumps the NMEA data correctly w/o any problem on my terminal.
One more thing to say, I am using interrupt handler to deal with the GSM stream.
Code: | #INT_RDA
rda()
int8 c;
c=fgetc(GSM);
if(c==10)
sbuf[scnt-1]=0;
scnt = 0;
sflag=1;
} else
sflag = 0;
sbuf[scnt++]=c;
Any idea? |
Humberto
Posted: Wed Sep 29, 2004 12:46 pm |
In your interrupt handler, I would try the following just to quit the interrupt handler as soon as posible.
#INT_RDA
rda()
int8 c;
if(kbhit(GSM))
c=fgetc(GSM);
if(c==10)
sbuf[scnt-1]=0;
scnt = 0;
sflag=1;
}else
sflag = 0;
sbuf[scnt++]=c;
best wishes,
Humberto |
