Driver LCD based on Toshiba T6963c
Damien
PostPosted: Mon Jan 14, 2002 12:12 am     Reply with quote
Does anyone have a driver for the Graphiqe LCD toshiba T6963 C
driver based
I want to find exemple to write; circle, dot line etc ..
Thank for all
___________________________
Original Post ID: 1993
Todd C. Micallef
Re: Driver LCD based on Toshiba T6963c
PostPosted: Mon Jan 14, 2002 7:42 am     Reply with quote
:=Does anyone have a driver for the Graphiqe LCD toshiba T6963 C
:=driver based
:=I want to find exemple to write; circle, dot line etc ..
:=Thank for all
Try the following link...
Also, a great place to go is the Pic /Ubicom developers website at...
<a href="http://www.devrs.com/pic/" TARGET="_blank">http://www.devrs.com/pic/</a>
Original Post ID: 1997
johnpcunningham
PostPosted: Fri Jan 25, 2002 2:04 pm     Reply with quote
YEs, I have writen my own and it works well
Original Post ID: 2222
Analyzer
PostPosted: Wed Nov 26, 2003 6:31 pm     Reply with quote
Sir,
Would you share your T6963C library with us please? I can not understand Pbp. Embarassed
Analyzer.
PostPosted: Wed Nov 26, 2003 7:00 pm     Reply with quote
You're responding to a post that's almost 2 years old.
I don't think J.C. is on this board anymore.
If he was, he might be fighting with Hans Smile
A quick search with Google finds some source code
for the C2C compiler (close enough to CCS):
http://www.picant.com/c2c/examples/t6963/t6963.c.html
And for the Hi-Tech C compiler:
http://www.njqrp.org/ham-pic/T6963LCD.c
Analyzer
PostPosted: Thu Nov 27, 2003 8:29 am     Reply with quote
Thank you for your quick reply.I didnt pay attention to date Smile The c2c and hi-tect is not close enough to ansi c compiler and also ccs so i decided to write my own code.I found a pdf of steve lawther so i started to work.If somebody has an instant ccs c solution for this controller, it would be veery nice Smile
Analyzer
john zar
code for t6963c with CCS compiler
PostPosted: Wed Sep 29, 2004 9:22 am     Reply with quote
I have problems with my graphic lcd based in t6963c. Someone have the code necesary to drive this controller
PostPosted: Wed Sep 29, 2004 1:16 pm     Reply with quote
Did you look at the links in the posts above ?
Did you look at the CCS code library ?
It has code for that chip.
http://www.ccsinfo.com/forum/viewforum.php?f=2
