rafa
I need help with my graphic lcd based in T6963C |
Posted: Tue Sep 28, 2004 10:32 am |
I can't make my lcd function. I have found code for it but it isn't sufficient.
Please, someboby give me the code. I already have been 1 month workng and i don't find a solution.
Thanks, rafa |
Oznog
Posted: Sat Oct 16, 2004 1:59 am |
What is it doing?
Post your code, maybe we can fix it? I've done T6963C, graphics tasks, graphical fonts, it's all good.
And- the question that will make you find something breakable around you and smash it if this is it- did you give it the appropriate -Vee? Display won't show anything without it! |
Mark
Posted: Sat Oct 16, 2004 10:28 am |
Then post your question in the other forum. This one is for posting code to share with others and not for asking questions. Also do a search. That is the first thing you should do. I know I have seen routines posted for that controller. Heck, it is even in this forum!!!
http://www.ccsinfo.com/forum/viewtopic.php?t=19957&highlight=t6963c |
rafa
Posted: Mon Oct 18, 2004 5:02 am |
This is the code i'm using. Initially this war for a pic18f452. I have intented change it but i can't get function it for my pic16f877.
//// EX_GLCD.C ////
//// This example program demonstrates the use of a graphic LCD. ////
//// A reading is taken by the analog to digital converter and ////
//// displayed on the LCD. A bar shows the current reading relative ////
//// to the minimum and maximum values. If the reading is greater ////
//// than 4 volts, a warning message is displayed. A clock timer ////
//// demonstrates the use of the circle and line functions and shows ////
//// that the program is active. ////
//// (C) Copyright 1996,2003 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS ////
//// C compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, ////
//// reproduction or distribution is permitted without written ////
//// permission. Derivative programs created using this software ////
//// in object code form are not restricted in any way. ////
#if defined(__PCM__)
#include <16f877.h> //CAMBIO
#CASE
//#fuses HS,NOWDT,PROTECT,NOLVP,WRT,BROWNOUT,BORV45,NODEBUG,STVREN,PUT,NODEBUG
#fuses HS,NOWDT,NOPROTECT,NOLVP,PUT,BROWNOUT
//CAMBIO: he cambiado este fuses por el de arriba + put + brownout
//#fuses HS,NOWDT,PROTECT,NOLVP,WRT,BROWNOUT,BORV45,NODEBUG,STVREN,PUT,NODEBUG,WRT,WRTD,WRTB,WRTC,CPD,CPB
#use delay(clock=4000000) //CAMBIO: ulilizo una velocidad de 4000000
//CAMBIOS:¿hacen falta las 3 proximas lineas?
//#use rs232(baud=38400,xmit=PIN_C4,INVERT,stream=DEBUG) // STDERR(same as DEBUG)
//#use rs232(baud=38400,xmit=PIN_C4,INVERT,stream=STDERR) // STDERR(same as DEBUG)
//#use rs232(baud=19200,xmit=PIN_C6,rcv=PIN_C7,stream=RS485) // RS485 is the default
#zero_ram
#use fast_io(D) //CAMBIO
#include <stdlib.h>
//#include <stdlibm.h> //AQUI ESTA EL ERROR
#include <math.h>
int16 ERRORS;
#include "LCD_T6963C.h" //CAMBIO: incluyo esta libreria
void displayVoltage(int data) {
char voltValue[9]; // Stores the converted number
sprintf(voltValue, "%f", (float)data * .01960784);// Converts number to text
voltValue[4] = '\0'; // Limit shown digits to 3
glcd_rect(45, 18, 69, 25, YES, OFF); // Clear the old number
glcd_text57(45, 18, voltValue, 1, ON); // Write the new number
int value1 = 0, value2 = 0, Warn = 0;
char voltText[] = "Volts", warning[] = "Warning";
float theta = 0;
//setup_adc_ports(RA0_ANALOG); // Set the ADC to read A0
//setup_adc(ADC_CLOCK_INTERNAL); // Set the ADC clock
//set_adc_channel(0); // Set ADC to use channel 0
glcd_init(ON);
glcd_WriteCmd0(LCDDispMode | LCDDisp_GRH); // Must initialize the LCD
//glcd_rect(1, 5, 126, 15, NO, ON); // Draw the rectangle around the bar
glcd_text57(70, 18, voltText, 1, ON); // Write "Volts" on the LCD
glcd_circle(30, 47, 10, NO, ON); // Draw the clock circle
do{value1 = read_adc(); // Read a value from the ADC
displayVoltage(value1); // Display the reading
value1 = (value1 > 250) ? 250 : value1; // Keep the value under 251
if(value1 > 200 && !Warn) { // Check if reading is above 200
glcd_rect(45, 38, 124, 55, YES, ON); // Draw a filled black rectangle
glcd_text57(47, 40, warning, 2, OFF); // Write "Warning" on the LCD
Warn = 1; }
else if(value1 <=200){
glcd_rect(45, 37, 125, 55, YES, OFF); // Draw a filled white rectangle
Warn = 0; }
// The following 3 lines make the clock hand spin around
glcd_line(30, 47, 30+(int)(8*sin(theta)+.5), 47-(int)(8*cos(theta)+.5), OFF);
theta = (theta > 5.9) ? 0 : (theta += .3);
glcd_line(30, 47, 30+(int)(8*sin(theta)+.5), 47-(int)(8*cos(theta)+.5), ON);
glcd_rect(value1/2, 6, value2/2, 14, YES, OFF); // Clears the old bar
glcd_rect(1, 6, value1/2, 14, YES, ON); // Draws a new bar
value2 = value1; // Set old value to new
delay_ms(150); // Delay for a bit
} while (TRUE);
// Notice : Copyright (c) 2004 Sentinel Systems Corporation
// : All Rights Reserved
// Date : 01-05-2004
// Version: 1.0
//// LCD_T6963C.c
//// This file contains drivers for using a Tosiba T6963C controller ////
//// in parallel/8080(intel) mode. The T6963C is 240 pixels across ////
//// and 64 pixels down. The driver treats the upper left pixel 0,0 ////
//// glcd_init(mode) ////
//// glcd_pixel(x,y,color) ////
//// glcd_line(x1,y1,x2,y2,color) ////
//// glcd_rect(x1,y1,x2,y2,fill,color) ////
//// glcd_bar(x1,y1,x2,y2,width,color) ////
//// glcd_circle(x,y,radius,fill,color) ////
//// glcd_text57(x,y,textptr,size,color) ////
//// glcd_fillScreen(color) ////
//5/25/2004 9:26AM consolidating pins on port A & D
//5/25/2004 10:06AM consolidating pins on port C & D
//5/26/2004 7:48AM V1.2.4
//5/26/2004 7:48AM Fixing little graphics problems
//5/26/2004 10:22AM V1.2.5
//5/27/2004 8:31AM V1.2.6 Good LCD, RX/TX, now working on keypad
#ifndef GLCD_COL
#define GLCD_COL 240 // Used for text wrapping by glcd_text57 function and sanity check
#ifndef GLCD_ROW
#define GLCD_ROW 128 //CAMBIO: 64 en vez de 128
#define ON 1
#define OFF 0
#define YES 1
#define NO 0
#define set_tris_lcd(x) set_tris_c(0b00000000);set_tris_d(x) //CAMBIO: 0b00000000 por 0b10000000
#define set_lcd_defaults(x) set_tris_lcd(0xFF);LCD.w_bar=1;LCD.r_bar=1;LCD.cd=1;LCD.reset=1 //CAMBIO:RESET
#define glcd_WriteCmd0(x) glcd_WriteByte(1,x)
#define DispScn(x) glcd_WriteCmd2(TextHome+240*x,0x80) //CAMBIO: 0x80 por 0x40
#define LCDTxtAdr(s,x,y) 0x780+(240*s)+(AreaSet_T*y)+x
#define LCDSetPtr 0x24
//FS=0, 5x7 char in 8x8 field, 30char/line, 240 char total,graphic pics 8pixels/address, 0x780 grh addresses
//FS=1, 5x7 char in 6x8 field, 40char/line, 320 char total,graphic pics 6pixels/address, 0xA00 grh addresses
// - - - - 64K RAM - - - - 0 to 0xFFFF
// 0 grh home
// grh end (right before txt home)
// 0x780----(screen 0) or 0xA00 Txt home depends on FS
// 0x870----(screen 1) adding 240 for each screen
// 0x960----(screen 2)
// 0xA50----(screen 3)
const int1 LCDFont = 0;//FS pin has internal pull-up. FS=1 unless grounded
const int8 LCDField = 8+(!LCDFont*2); //CAMBIO:8 POR 6 //FS=1 then field=6. FS=0 then field=8
const int8 LCDCharWidth = GLCD_COL /LCDField;
const int16 CharPerScn= LCDCharWidth*16; //CAMBIO: 16 por 8 //number of characters on a screen
const int16 GraphicsHome=0x0000; //RAM area where graphics is held
const int8 AreaSet_G= 30+(LCDFont*10); //how many bytes before a new line
const int16 TextHome = (GLCD_COL/LCDField)*128; //CAMBIO: 128 por 64//text comes right after graphics area
const int8 AreaSet_T= 30+(LCDFont*10); //how many bytes before a new line. 30 or 40
const int8 AutoModeWrite=0xB0;
const int8 AutoModeRead =0xB1;
const int8 AutoModeReset=0xB2;
const int8 LCDModeSet = 0x80;//send this OR'd with the following
const int8 LCDMode_OR = 0b0000;
const int8 LCDMode_XOR = 0b0001;
const int8 LCDMode_AND = 0b0010;
const int8 LCDMode_TA = 0b0100; //TEXT ATTRIBUTE mode.
const int8 LCDMode_RAM = 0b1000; //1=CG RAM, 0=internal CG ROM
const int8 LCDSetCursorPtr =0x21; //Cursor position
const int8 LCDSetCursorSize=0xA0; //Number of lines in the cursor
const int8 LCDDispMode = 0x90;//send this OR'd with the following
const int8 LCDDisp_BLK = 0b0001;
const int8 LCDDisp_CUR = 0b0010;
const int8 LCDDisp_TXT = 0b0100;
const int8 LCDDisp_GRH = 0b1000;
const int8 LCDMaxBusyCount = 4;//will try count-1 times before giving up
//#include <stdlibm.h> //CAMBIO: lo puse yo
struct lcd_pin_def
BOOLEAN fs1; // C0
BOOLEAN md2; // C1
BOOLEAN reset; // C2
BOOLEAN ce; // C3
BOOLEAN w_bar; // C4 Write bar active low
BOOLEAN r_bar; // C5 Read bar active low
BOOLEAN cd; // C6 Command/Data BCR 1=command 0=data
BOOLEAN unusedC7; // C7
//BOOLEAN unusedC4; // C4
//BOOLEAN unusedC5; // C5
//BOOLEAN unusedC6; // C6
//BOOLEAN unusedC7; // C7
// int data : 8; // D=Data bus
struct lcd_pin_def LCD;
struct lcd_pin_def1
int data:8;
struct lcd_pin_def1 LCD1;
#byte LCD = 0x07 //CAMBIO //note: no semicolin 5=A0 on a 16F877A
//int data[8];
#byte LCD1 = 0x08
//#use fast_io(C)
//#use fast_io(D)
//#byte LCD = 0xF82 //note: no semicolin 5=A0 on a 16F877A
#bit LCDSTA0 = 0x8.0 //CAMBIO: he cambiado las proximas direcciones
#bit LCDSTA1 = 0x8.1
#bit LCDSTA2 = 0x8.2
#bit LCDSTA3 = 0x8.3
//---------------- Prototypes--------------------
//void glcd_FontSelect(int1 fs);
glcd_WriteByte(int1 cd, BYTE data);
glcd_WriteByteAuto(BYTE data);
BYTE glcd_ReadByte();
BYTE glcd_ReadByteAuto();
glcd_WriteCmd1(BYTE data, BYTE cmd);
glcd_WriteCmd2(int16 data, BYTE cmd);
glcd_pixel(int16 x,int16 y,int1 color);
glcd_clr(int16 location, int16 size);
void glcd_CpyScn(unsigned int16 ptr1,unsigned int16 ptr2);
// INICIALIZACION //
void glcd_init(int1 mode)
//fprintf(DEBUG,"LCD init\n\r");
set_lcd_defaults();
//reset
//LCD.w_bar=0; // preform a reset. When w_bar=0 & r_bar=0 then reset_bar=0
//LCD.r_bar=0; // preform a reset.
LCD.reset=0; //reset
delay_ms(1); // delay 1ms minimo,CAMBIO:yo pongo 2 por ejemplo
LCD.reset=1;
LCD.fs1=0;
LCD.md2=0;
LCD.ce=0;
//LCD.w_bar=1; // run
//LCD.r_bar=1; //
//Set up the graphics and text areas
glcd_WriteCmd2(TextHome,0x40); //set text home
glcd_WriteCmd2(AreaSet_T,0x41); //set text area
glcd_WriteCmd2(GraphicsHome,0x42);//set graphics home
glcd_WriteCmd2(AreaSet_G,0x43); //set graphics area
//cursor
glcd_WriteCmd0(LCDSetCursorSize | (0x01-1));//1 line cursor
glcd_WriteCmd2(0x0000,LCDSetCursorPtr);//0x yy xx , cursor position
//modes
glcd_WriteCmd0(LCDModeSet | LCDMode_XOR);
//glcd_WriteCmd0(LCDDispMode | LCDDisp_TXT |LCDDisp_BLK | LCDDisp_CUR);
glcd_WriteCmd0(LCDDispMode | LCDDisp_TXT);
//offset register
glcd_WriteCmd2(0x0002,0x22);//offset register=0x0002
//Clear all RAM of LCD
glcd_clr(0x0000,0xFFFF);//Clear all of RAM
//fprintf(DEBUG,"LCD init DONE.\n\r");
// Purpose: Copys a screen(CharPerScn bytes) from ptr2 to ptr1
// Inputs: ptr1 ptr2
// Ouputs:
int8 x;
int8 temp_array[128]; //CAMBIO
////fprintf(DEBUG,"ptr1=%lx ptr2=%lx\n\r",ptr1,ptr2);
//read data and put in array
glcd_WriteCmd2(ptr2,LCDSetPtr);
glcd_WriteCmd0(AutoModeRead);
for (x=0;x<CharPerScn;x++)
temp_array[x]=glcd_ReadByteAuto();
////fprintf(DEBUG,"0x%lx<-0x%x ",ptr2+x,temp_array[x]);
glcd_WriteCmd0(AutoModeReset);
//write data from array
glcd_WriteCmd2(ptr1,LCDSetPtr);
glcd_WriteCmd0(AutoModeWrite);
glcd_WriteByteAuto(temp_array[x]);
////fprintf(DEBUG,"0x%x->0x%lx ",temp_array[x],ptr1+x);
// Purpose: Writes a byte of data from the current location
// Inputs: cd 1=command 0=data BYTE data
// Ouputs: Int1 1=success 0=failure
void glcd_WriteByte(int1 cd, BYTE data)
set_lcd_defaults();
LCD.r_bar=0; // Read
while(!LCDSTA0 && !LCDSTA1) //CAMBIO:&& por || //wait till both are one
////fprintf(DEBUG,".");
LCD.r_bar=1; // Release
// if(cd==0) {//fprintf(DEBUG,"D=%lx ",data);}
// if(cd==1) {//fprintf(DEBUG,"C=%lx ",data);}
set_tris_lcd(0x00); //All outputs
LCD.cd=cd; //Command/Data bar
LCD1.data=data;
LCD.w_bar=0; //write
set_lcd_defaults();
// Purpose: Writes continuous bytes of data from the current location
// Inputs: BYTE data
void glcd_WriteByteAuto(BYTE data)
set_lcd_defaults();
while(!LCDSTA3) //wait till STA3 is one
LCD.cd=0; //This is always data, cd=0
LCD1.data=data; //Put data on data bus
set_lcd_defaults();
// Purpose: Reads continuous bytes of data from the current location, and inc
// Ouputs: Data byte read
BYTE glcd_ReadByteAuto(void)
int8 data;
set_lcd_defaults();
while(!LCDSTA2) //wait till STA2 is one
set_tris_lcd(0xff); // All inputs
LCD.cd=0; // This is always data, cd=0
data=LCD1.data; // Read data bus
set_lcd_defaults();
return (data); //Return status
// Purpose: Writes a one byte of data and a command
// Inputs: BYTE data BYTE cmd
void glcd_WriteCmd1(BYTE data, BYTE cmd)
glcd_WriteByte(0,data);
glcd_WriteCmd0(cmd);
// Purpose: Writes a two data byte command
// Inputs: int16 data BYTE cmd
void glcd_WriteCmd2(int16 data, BYTE cmd)
int8 lcddata;
// glcd_WriteByte(0,data & 0xFF);
// glcd_WriteByte(0,data>>8);
// glcd_WriteCmd0(cmd);
// - - - - - - - - - - - - data - - - - - - - - -
set_lcd_defaults();
lcddata=data & 0xFF;
while(!LCDSTA0 && !LCDSTA1) //CAMBIO:&& por || //wai t till both are one
LCD.cd=0; //Command/Data bar
LCD1.data=lcddata;
set_lcd_defaults();
lcddata=data>>8;
LCD1.data=lcddata;
// - - - - - - - - - - - - command- - - - - - - -
set_lcd_defaults();
LCD.cd=1; //Command/Data bar
LCD1.data=cmd;
set_lcd_defaults();
// Purpose: Clears LCD RAM
void glcd_clr(int16 location,int16 size)
////fprintf(DEBUG,"loc=%lu size=%lu\n\r",location,size);
glcd_WriteCmd2(location,LCDSetPtr);
for (;size;size--)
glcd_WriteByteAuto(0x00);//clear ram
// Purpose: Reads a byte of data from the current location
// Ouputs: A byte of data read from the LCD
int8 data=0;
//do a read and don't inc command
glcd_WriteCmd0(0xc5);
set_lcd_defaults();
LCD.cd=0; // Command/Data bar
data=LCD1.data; // Latch data
set_lcd_defaults();
////fprintf(DEBUG,"-0x%x-",data);
return(data); //Return the read data
// Purpose: Sends data to LCD
void glcd_putc( char c) {
////fprintf(DEBUG,"P=0x%x ",c);
switch (c) {
// case '\f' : lcd_send_byte(0,1);
// delay_ms(2);
// break;
// case '\n' : lcd_gotoxy(1,2); break;
// case '\b' : lcd_send_byte(0,0x10); break;
default : glcd_WriteCmd1(c-0x20,0xc0);break;//Write to LCD autoinc
// Purpose: Turn a pixel on a graphic LCD on or off
// Inputs: x - the x coordinate of the pixel
// y - the y coordinate of the pixel
// color - ON or OFF
// Output: 1 if coordinate out of range, 0 if in range
glcd_pixel(int16 x,int16 y, int1 color)
int8 r=0,c=0;
c=color;//converting booean to an int8
if (x>=GLCD_COL)
bit_set(ERRORS,5);//ERRORS=bit 5. LCD x range exceeded
return (FALSE);
if (y>=GLCD_ROW)
bit_set(ERRORS,6);//ERRORS=bit 6. LCD y range exceeded
return (FALSE);
r=fmod(x,8);
glcd_WriteCmd2(GraphicsHome+(y*30+(x/8)),LCDSetPtr);
glcd_WriteCmd0(0xf0|(c<<3) |(7-r));
// Purpose: Draw a line on a graphic LCD using Bresenham's
// line drawing algorithm
// Inputs: (x1, y1) - the start coordinate
// (x2, y2) - the end coordinate
// Dependencies: glcd_pixel()
void glcd_line(int x1, int y1, int x2, int y2, int1 color)
signed int x, y, addx, addy, dx, dy;
signed long P;
int i;
dx = abs((signed int)(x2 - x1));
dy = abs((signed int)(y2 - y1));
x = x1;
y = y1;
if(x1 > x2)
addx = -1;
addx = 1;
if(y1 > y2)
addy = -1;
addy = 1;
if(dx >= dy)
P = 2*dy - dx;
for(i=0; i<=dx; ++i)
glcd_pixel(x, y, color);
if(P < 0)
P += 2*dy;
x += addx;
P += 2*dy - 2*dx;
x += addx;
y += addy;
P = 2*dx - dy;
for(i=0; i<=dy; ++i)
if(P < 0)
P += 2*dx;
y += addy;
P += 2*dx - 2*dy;
x += addx;
y += addy;
// Purpose: Draw a rectangle on a graphic LCD
// fill - YES or NO
// Dependencies: glcd_pixel(), glcd_line()
void glcd_rect(int x1, int y1, int x2, int y2, int fill, int1 color)
if(fill)
int y, ymax; // Find the y min and max
if(y1 < y2)
y = y1;
ymax = y2;
y = y2;
ymax = y1;
for(; y<=ymax; ++y) // Draw lines to fill the rectangle
glcd_line(x1, y, x2, y, color);
glcd_line(x1, y1, x2, y1, color); // Draw the 4 sides
glcd_line(x1, y2, x2, y2, color);
glcd_line(x1, y1, x1, y2, color);
glcd_line(x2, y1, x2, y2, color);
// Purpose: Draw a bar (wide line) on a graphic LCD
// width - The number of pixels wide
void glcd_bar(int x1, int y1, int x2, int y2, int width, int1 color)
signed int x, y, addx, addy, j;
signed long P, dx, dy, c1, c2;
int i;
x = x1;
y = y1;
c1 = -dx*x1 - dy*y1;
c2 = -dx*x2 - dy*y2;
if(x1 > x2)
addx = -1;
c1 = -dx*x2 - dy*y2;
c2 = -dx*x1 - dy*y1;
addx = 1;
if(y1 > y2)
addy = -1;
addy = 1;
if(dx >= dy)
P = 2*dy - dx;
for(j=-(width/2); j<width/2+width%2; ++j)
if(dx*x+dy*(y+j)+c1 >= 0 && dx*x+dy*(y+j)+c2 <=0)
glcd_pixel(x, y+j, color);
if(P < 0)
P += 2*dy;
x += addx;
P += 2*dy - 2*dx;
x += addx;
y += addy;
P = 2*dx - dy;
if(P < 0)
P += 2*dx;
y += addy;
P += 2*dx - 2*dy;
x += addx;
y += addy;
glcd_pixel(x+j, y, color);
// Purpose: Draw a circle on a graphic LCD
// Inputs: (x,y) - the center of the circle
// radius - the radius of the circle
// fill - YES or NO
void glcd_circle(int x, int y, int radius, int1 fill, int1 color)
signed int a, b, P;
a = 0;
b = radius;
P = 1 - radius;
do
if(fill)
glcd_line(x-a, y+b, x+a, y+b, color);
glcd_line(x-a, y-b, x+a, y-b, color);
glcd_line(x-b, y+a, x+b, y+a, color);
glcd_line(x-b, y-a, x+b, y-a, color);
glcd_pixel(a+x, b+y, color);
glcd_pixel(b+x, a+y, color);
glcd_pixel(x-a, b+y, color);
glcd_pixel(x-b, a+y, color);
glcd_pixel(b+x, y-a, color);
glcd_pixel(a+x, y-b, color);
glcd_pixel(x-a, y-b, color);
glcd_pixel(x-b, y-a, color);
if(P < 0)
P+= 3 + 2*a++;
P+= 5 + 2*(a++ - b--);
} while(a <= b);
const BYTE TEXT[51][5] ={ 0x00, 0x00, 0x00, 0x00, 0x00, // SPACE
0x00, 0x00, 0x5F, 0x00, 0x00, // !
0x00, 0x03, 0x00, 0x03, 0x00, // "
0x14, 0x3E, 0x14, 0x3E, 0x14, // #
0x24, 0x2A, 0x7F, 0x2A, 0x12, // $
0x43, 0x33, 0x08, 0x66, 0x61, // %
0x36, 0x49, 0x55, 0x22, 0x50, // &
0x00, 0x05, 0x03, 0x00, 0x00, // '
0x00, 0x1C, 0x22, 0x41, 0x00, // (
0x00, 0x41, 0x22, 0x1C, 0x00, // )
0x14, 0x08, 0x3E, 0x08, 0x14, // *
0x08, 0x08, 0x3E, 0x08, 0x08, // +
0x00, 0x50, 0x30, 0x00, 0x00, // ,
0x08, 0x08, 0x08, 0x08, 0x08, // -
0x00, 0x60, 0x60, 0x00, 0x00, // .
0x20, 0x10, 0x08, 0x04, 0x02, // /
0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
0x04, 0x02, 0x7F, 0x00, 0x00, // 1
0x42, 0x61, 0x51, 0x49, 0x46, // 2
0x22, 0x41, 0x49, 0x49, 0x36, // 3
0x18, 0x14, 0x12, 0x7F, 0x10, // 4
0x27, 0x45, 0x45, 0x45, 0x39, // 5
0x3E, 0x49, 0x49, 0x49, 0x32, // 6
0x01, 0x01, 0x71, 0x09, 0x07, // 7
0x36, 0x49, 0x49, 0x49, 0x36, // 8
0x26, 0x49, 0x49, 0x49, 0x3E, // 9
0x00, 0x36, 0x36, 0x00, 0x00, // :
0x00, 0x56, 0x36, 0x00, 0x00, // ;
0x08, 0x14, 0x22, 0x41, 0x00, // <
0x14, 0x14, 0x14, 0x14, 0x14, // =
0x00, 0x41, 0x22, 0x14, 0x08, // >
0x02, 0x01, 0x51, 0x09, 0x06, // ?
0x3E, 0x41, 0x59, 0x55, 0x5E, // @
0x7E, 0x09, 0x09, 0x09, 0x7E, // A
0x7F, 0x49, 0x49, 0x49, 0x36, // B
0x3E, 0x41, 0x41, 0x41, 0x22, // C
0x7F, 0x41, 0x41, 0x41, 0x3E, // D
0x7F, 0x49, 0x49, 0x49, 0x41, // E
0x7F, 0x09, 0x09, 0x09, 0x01, // F
0x3E, 0x41, 0x41, 0x49, 0x3A, // G
0x7F, 0x08, 0x08, 0x08, 0x7F, // H
0x00, 0x41, 0x7F, 0x41, 0x00, // I
0x30, 0x40, 0x40, 0x40, 0x3F, // J
0x7F, 0x08, 0x14, 0x22, 0x41, // K
0x7F, 0x40, 0x40, 0x40, 0x40, // L
0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
0x7F, 0x02, 0x04, 0x08, 0x7F, // N
0x3E, 0x41, 0x41, 0x41, 0x3E, // O
0x7F, 0x09, 0x09, 0x09, 0x06, // P
0x1E, 0x21, 0x21, 0x21, 0x5E, // Q
0x7F, 0x09, 0x09, 0x09, 0x76};// R
const BYTE TEXT2[44][5]={ 0x26, 0x49, 0x49, 0x49, 0x32, // S
0x01, 0x01, 0x7F, 0x01, 0x01, // T
0x3F, 0x40, 0x40, 0x40, 0x3F, // U
0x1F, 0x20, 0x40, 0x20, 0x1F, // V
0x7F, 0x20, 0x10, 0x20, 0x7F, // W
0x41, 0x22, 0x1C, 0x22, 0x41, // X
0x07, 0x08, 0x70, 0x08, 0x07, // Y
0x61, 0x51, 0x49, 0x45, 0x43, // Z
0x00, 0x7F, 0x41, 0x00, 0x00, // [
0x02, 0x04, 0x08, 0x10, 0x20, // \
0x00, 0x00, 0x41, 0x7F, 0x00, // ]
0x04, 0x02, 0x01, 0x02, 0x04, // ^
0x40, 0x40, 0x40, 0x40, 0x40, // _
0x00, 0x01, 0x02, 0x04, 0x00, // `
0x20, 0x54, 0x54, 0x54, 0x78, // a
0x7F, 0x44, 0x44, 0x44, 0x38, // b
0x38, 0x44, 0x44, 0x44, 0x44, // c
0x38, 0x44, 0x44, 0x44, 0x7F, // d
0x38, 0x54, 0x54, 0x54, 0x18, // e
0x04, 0x04, 0x7E, 0x05, 0x05, // f
0x08, 0x54, 0x54, 0x54, 0x3C, // g
0x7F, 0x08, 0x04, 0x04, 0x78, // h
0x00, 0x44, 0x7D, 0x40, 0x00, // i
0x20, 0x40, 0x44, 0x3D, 0x00, // j
0x7F, 0x10, 0x28, 0x44, 0x00, // k
0x00, 0x41, 0x7F, 0x40, 0x00, // l
0x7C, 0x04, 0x78, 0x04, 0x78, // m
0x7C, 0x08, 0x04, 0x04, 0x78, // n
0x38, 0x44, 0x44, 0x44, 0x38, // o
0x7C, 0x14, 0x14, 0x14, 0x08, // p
0x08, 0x14, 0x14, 0x14, 0x7C, // q
0x00, 0x7C, 0x08, 0x04, 0x04, // r
0x48, 0x54, 0x54, 0x54, 0x20, // s
0x04, 0x04, 0x3F, 0x44, 0x44, // t
0x3C, 0x40, 0x40, 0x20, 0x7C, // u
0x1C, 0x20, 0x40, 0x20, 0x1C, // v
0x3C, 0x40, 0x30, 0x40, 0x3C, // w
0x44, 0x28, 0x10, 0x28, 0x44, // x
0x0C, 0x50, 0x50, 0x50, 0x3C, // y
0x44, 0x64, 0x54, 0x4C, 0x44, // z
0x00, 0x08, 0x36, 0x41, 0x41, // {
0x00, 0x00, 0x7F, 0x00, 0x00, // |
0x41, 0x41, 0x36, 0x08, 0x00, // }
0x02, 0x01, 0x02, 0x04, 0x02};// ~
// Purpose: Write text on a graphic LCD
// Inputs: (x,y) - The upper left coordinate of the first letter
// textptr - A pointer to an array of text to display
// size - The size of the text: 1 = 5x7, 2 = 10x14, ...
void glcd_text57(int x, int y, char* textptr, int size, int1 color)
const BYTE bytes_per_char=5;
int i, j, k, l, m; // Loop counters
BYTE pixelData[bytes_per_char]; // Stores character data
for(i=0; textptr[i] != '\0'; ++i, ++x) // Loop through the passed string
if(textptr[i] < 'S') //falta un = // Checks if the letter is in the first or second array
memcpy(pixelData, TEXT[textptr[i]-' '], bytes_per_char);
else if(textptr[i] <= '~') // Check if the letter is in the second array
memcpy(pixelData, TEXT2[textptr[i]-'S'], bytes_per_char);
memcpy(pixelData, TEXT[0], bytes_per_char); // Default to space
if(x+5*size >= GLCD_COL) // Performs character wrapping
x = 0; // Set x at far left position
y += 7*size + 1; // Set y at next position down
for(j=0; j<bytes_per_char; ++j, x+=size) // 5 bytes per character
for(k=0; k<7*size; ++k) // Loop through the vertical pixels
if(bit_test(pixelData[j], k)) // Check if the pixel should be set
for(l=0; l<size; ++l) // The next two loops change the
{ // character's size
for(m=0; m<size; ++m)
glcd_pixel(x+m, y+k*size+l, color); // Draws the pixel
//// Purpose: Fill the LCD screen with the passed in color.
//// Works much faster than drawing a rectangle to fill the screen
//// Inputs: ON - turn all the pixels on
//// OFF - turn all the pixels off
//// Dependencies: glcd_WriteByte()
//void glcd_fillScreen(int1 color)
// int line_num, column;
// // Loop through the lines
// //fprintf(DEBUG,"Fill screen with %d\n\r",color);
// for(line_num = 0; line_num < 8; ++line_num)
// glcd_WriteByte(0, 0xB0+line_num);
// glcd_WriteByte(0, 0x10);
// glcd_WriteByte(0, 0x00);
// // Loop through the horline_numzontal sectline_numons
// for(column = 0; column < 128; ++column)
// glcd_WriteByte(1, 0xFF*color); // Turn all pixels on or off
//// Purpose: Selects a font and sets up areas
//// Ouputs: A bit that is applied to the FS(font select) pin
//void glcd_FontSelect(int1 fs) {
// LCD.fs=fs;
// switch (fs)
// case 1:
// glcd_WriteCmd2(TextHome,0x40);
// glcd_WriteCmd2(AreaSet_T,0x41);
// glcd_WriteCmd2(GraphicsHome,0x42);
// glcd_WriteCmd2(AreaSet_G,0x43);
// break;
// default:
// glcd_WriteCmd1(c-0x20,0xc0);
// break;
////////////////////////////////JUNK YARD ////////////////////////////////////
////// Purpose: Reads status of LCD
////// Ouputs: Returns 1=busy 0=not busy
////int1 glcd_notbusy()
//// BYTE data,count=0; // Stores the data read from the LCD
//// do
//// set_tris_lcd(0xFF) ; // Port D inputs
//// LCD.cd=1; //Instruction
//// LCD.r_bar=0; //Read
//// LCD.w_bar=1; //not write
//// data=LCD.data;
//// LCD.r_bar=1; //Release Read
//// set_tris_lcd(0xFF);//Port D tristate
//// ++count;
////// //fprintf(DEBUG,"count=%U\r",count);
//// if (count>3){return(0);}
//// }while (!bit_test(data,1) || !bit_test (data,0) );//til bit0 and bit1==1
//// return (1); //Return status
