object01
Joined: 13 May 2004 Posts: 90 Location: Nashville, TN
| Can't achieve 115200 baud on PIC18F2320 at 6MHz |
Posted: Tue Sep 28, 2004 8:42 am |
According to the formula in the 2320's datasheet, I should be able to achieve 115200 baud within <1% error if I run the internal oscillator at 6000000. But when I setup all this machinery,
| Code: | #include <18F2320.h>
#device *=16
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP,NOPROTECT,NOCPD,MCLR
#use delay (clock=6000000)
#use rs232 (baud=115200, xmit=PIN_C6, rcv=PIN_C7, errors, stream=PHONE) // Using the hardware USART |
The compiler tells me that the baud rate is out of range.
Is the compiler wrong, or is the formula wrong?
Jeff S. |
| Re: Can't achieve 115200 baud on PIC18F2320 at 6MHz |
Posted: Tue Sep 28, 2004 9:15 am |
| object01 wrote: | According to the formula in the 2320's datasheet, I should be able to achieve 115200 baud within <1% error if I run the internal oscillator at 6000000. But when I setup all this machinery,
#device *=16
Jeff S. |
I'd redo your calculation!...
The possible prescalers on this chip, are /16, or /64. With 115200, from a 6MHz clock, you want a total division by 6000000/115200 = 52.083. Using the smaller prescaler gives a multiplier of 3, and division by 3*16 = 48 (SPBRG value=2), with the minimum error of 8.5% (52.083/48). This is well out of acceptable limits.
In this case, I'd say the compiler was 'right'.
I think you might be misreading the data sheet, and accidentally using the _synchronous_ divisor value of 4, which would give the close value you are calculating (13*4=52, error = 0.015%). This is not an available divisor for asynchronous comms.
object01
Posted: Tue Sep 28, 2004 10:31 am |
Doh!
Thanks. :)
Jeff S. |
