Only 8 characters on my 2x16 LCD!!
Goto page 1, 2  Next
Yull
PostPosted: Fri Sep 24, 2004 7:52 am     Reply with quote
Hello, I've programmed my 2x16 hitachi powered LCD using LCD.c and I can't display "123456789ABCDEF" on the first line, I have just "12345678"!!!
Here is my code :
lcd_init();
delay_ms( 20 );
lcd_gotoxy(1,1);
delay_ms( 20 );
lcd_putc("\f123456789ABCDEF\n123456789ABCDEF");
Thanks by advance for your help
P.S.: I'm using a PIC16F873
RICHARD
PostPosted: Fri Sep 24, 2004 3:00 pm     Reply with quote
Dear Friend,
I am afriad you will have to submit the complete program list, including all the header configuration information!!!!
have you called the lcd.c --file??
is the lcd connected up correctly via port D??
Hope this helps
Richard
PostPosted: Fri Sep 24, 2004 3:05 pm     Reply with quote
Dear friend,
I am afraid that you can not have a "\n" operator,
if you want to operate on the next line you will have to have:
lcd gotoxy(x,y) //first line
lcd_putc("zzz")
lcd gotoxy(x,y) // second line
lcd_putc("zzz")
The \f, \n operator only works in the printf command!!
Regards,
jds-pic
PostPosted: Fri Sep 24, 2004 3:11 pm     Reply with quote
lcd_putc("zzz")
lcd_putc("zzz")
Regards,
or simply enable auto-wraparound in the LCD controller.
jds-pic
Yull
PostPosted: Fri Sep 24, 2004 3:24 pm     Reply with quote
Thanks for the replies, I will be trying those on Monday (week end now). Rolling Eyes
For information my LCD is put on PortB because the 16F873 don't have D port. Embarassed
Mark
PostPosted: Fri Sep 24, 2004 4:43 pm     Reply with quote
Dear All,
I tested his code and it worked just fine.
PostPosted: Fri Sep 24, 2004 4:49 pm     Reply with quote
The lcd_putc() function does support '\n'. See the code
from the CCS driver file, LCD.C, below:
void lcd_putc( char c) {
   switch (c) {
     case '\f'   : lcd_send_byte(0,1);
                   delay_ms(2);
     case '\n'   : lcd_gotoxy(1,2);        break;
     case '\b'   : lcd_send_byte(0,0x10);  break;
     default     : lcd_send_byte(1,c);     break;
Yull
PostPosted: Mon Sep 27, 2004 1:20 am     Reply with quote
Thanks a lot again for your help.
As requested, I put the entire source here :
#include "C:\Documents and Settings\xxx\Mes documents\PCW TEST\TEST.h"
#include <stdio.h>
#include <lcd.c>
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(FALSE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
set_tris_a (0);
lcd_init();
delay_ms( 20 );
lcd_putc("\f");
lcd_gotoxy(1,0);
delay_ms( 20 );
printf(lcd_putc,"\f123456789ABCDEF\n123456789ABCDEF");
//lcd_putc("\f123456789ABCDEF\n123456789ABCDEF");
delay_ms( 3000 );
lcd_putc("\f");
output_low(LED0);
output_low(LED1);
delay_ms( 1000 );
output_low(LED0);
output_high(LED1);
delay_ms( 1000 );
output_high(LED0);
output_low(LED1);
delay_ms( 1000 );
output_high(LED0);
output_high(LED1);
delay_ms( 1000 );
and my "test.h" :
#include <16F873.h>
#device adc=8
#use delay(clock=11059200)
#fuses HS, NOWDT, NOPROTECT, NOLVP, BROWNOUT, PUT
#define LED0 PIN_A0
#define LED1 PIN_A1
Thanks for help Smile
PostPosted: Mon Sep 27, 2004 1:43 am     Reply with quote
lcd_gotoxy(1,0);
The 2nd parameter value of 0 is not allowed by the CCS driver.
The lowest allowable value for each parameter is 1.
Here is the statement by CCS, from the LCD.C driver file:
lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1)
You should change your code to this:
lcd_gotoxy(1, 1);
Yull
PostPosted: Mon Sep 27, 2004 1:47 am     Reply with quote
You're right, but the problem still remains... Crying or Very sad
Yull
PostPosted: Mon Sep 27, 2004 5:42 am     Reply with quote
Not sure, but my LCD seems to be dead Evil or Very Mad
Mark
PostPosted: Mon Sep 27, 2004 6:18 am     Reply with quote
Did you make this board? If not, whose board is it?
PostPosted: Mon Sep 27, 2004 7:15 am     Reply with quote
Yes it's my board, i'm waiting for a new LCD to test my code Embarassed
Will Reeve
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Tue Sep 28, 2004 2:59 pm     Reply with quote
Not sure if it will help but the 1 x 16 line display I have just used is a bit of a pain! The first 8 characters are located at 0x00 to 0x07 in the LCD memory and the next 8 were located at 0x40 to 0x47 (usually where line 2 is stored!). Might be worth checking with the LCD manufacturer where the LCD text memory is located.
YulL
PostPosted: Wed Sep 29, 2004 4:12 am     Reply with quote
I've got my 2x16 LCD and I confirm that the last one was dead!!!
Grrrrrr Twisted Evil
Goto page 1, 2  Next
Page 1 of 2
