Willie Erasmus Guest
Measuring infrared pulses |
Posted: Wed Mar 26, 2003 2:51 am |
Hi there
I've seen the posting on "Measuring a pulse with 1us resolution", but Acetoel only want to measure one single pulse. I want to measure the successive pulses from the infrared reciever to decode the signal. Can somebody give me some direction how to do that. My infrared remote control transmits a signal with different pulse width indicating '0' or '1'. (Tested on digital scope)
Willie
___________________________
Original Post ID: 13071 |
Tomi Guest
Re: Measuring infrared pulses |
Posted: Wed Mar 26, 2003 3:14 am |
Maybe you don't need to measure the pulse width. Just wait for a rising edge then wait [("0" pulse width + "1" pulse width)/2] time then check the input line. If it is (already) "0" then the bit is 0. If it is (still) "1" then the bit is 1.
:=Hi there
:=I've seen the posting on "Measuring a pulse with 1us resolution", but Acetoel only want to measure one single pulse. I want to measure the successive pulses from the infrared reciever to decode the signal. Can somebody give me some direction how to do that. My infrared remote control transmits a signal with different pulse width indicating '0' or '1'. (Tested on digital scope)
:=Thanks
:=Willie
Original Post ID: 13072 |
Posted: Wed Mar 26, 2003 3:45 am |
<font face="Courier New" size=-1></font>
Original Post ID: 13075 |
Sherpa Doug Guest
Posted: Wed Mar 26, 2003 8:00 am |
Perhapse I can rephrase what Tomi said:
Let x be the length of a short pulse ("0").
Let y be the length of a long pulse ("1").
Assume pulses are active high.
1) Wait for the start of a pulse.
2) Wait (x+y)/2. By now a short pulse will have ended, but a long pulse will not have ended.
3) Test the input. If it is low it must have been a short pulse. If it is still high it must have been a long pulse.
4) Wait for the start of the next pulse....
SherpaDoug
:=Maybe you don't need to measure the pulse width. Just wait for a rising edge then wait [("0" pulse width + "1" pulse width)/2] time then check the input line. If it is (already) "0" then the bit is 0. If it is (still) "1" then the bit is 1.
:=:=Hi there
:=:=I've seen the posting on "Measuring a pulse with 1us resolution", but Acetoel only want to measure one single pulse. I want to measure the successive pulses from the infrared reciever to decode the signal. Can somebody give me some direction how to do that. My infrared remote control transmits a signal with different pulse width indicating '0' or '1'. (Tested on digital scope)
:=:=Thanks
:=:=Willie
Original Post ID: 13085 |
