MPLAB gets stuck in printf I want to simulate code |
Posted: Fri Sep 24, 2004 9:43 pm |
Code: | #define START PIN_B0
#define SIN PIN_B1
#define LOAD PIN_B2
#define RESET PIN_B3
#define XCK PIN_B4
#define READ PIN_B5
const char maskData = 0b10000000; //mask out the last bit to be shifted in data
const char maskAdr = 0b00000100; //mask out the last bit to be shifted in adr
void setDefalts(void)
//SET DEFALTS
output_low(START); //start=low
output_low(SIN); //sin.data=low
output_low(LOAD); //load=low
output_high(RESET); //reset=high
output_low(XCK); //Xck=low
void resetCam(void)
output_low(RESET); //pull reset low
output_high(XCK); //pull Xck high
output_high(RESET); //pull reset high
output_low(XCK); //pull Xck low
void resetCamDelay(void)//same as reset camera except delays so you can see it.
void loadReg(char reg)
output_bit(SIN,reg & maskAdr); //mask first bit of the adress and output
output_high(XCK); //clock data in
output_low(XCK);
reg=reg<<1; //shift left
output_low(XCK);
output_low(XCK);
void loadData(char data)
output_bit(SIN,data & maskData); //mask first bit of the data and output
output_low(XCK);
data=data<<1; //shift left
output_bit(SIN,data & maskData); //output 2nd bit
output_low(XCK);
output_bit(SIN,data & maskData); //output 3rd bit
output_low(XCK);
output_bit(SIN,data & maskData); //output fourth bit
output_low(XCK);
output_bit(SIN,data & maskData); //output fifth bit
output_low(XCK);
output_bit(SIN,data & maskData); //output 6th bit
output_low(XCK);
output_bit(SIN,data & maskData); //output 7th bit
output_low(XCK);
output_bit(SIN,data & maskData); //output 8th bit
output_high(LOAD); //load register
output_low(XCK);
output_low(LOAD);
void startCam(void)
{//START SEQUENCE
output_high(START); //pull start up
output_high(XCK); //pull clock up
output_low(START); //pull start low
output_low(XCK); //pull clock low
Code: | #include <16F877A.h>
#device adc=8
#fuses HS, NOWDT, NOLVP, BROWNOUT//never trust the wizard gizmo
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7)
#USE DYNAMIC_MEMORY//this could gain memory back after the function is over.
#include "C:\WINDOWS\Desktop\camera\GBCamera.h"
#ZERO_RAM
#int_AD
AD_isr()
int i= 1;
port_b_pullups(TRUE);
setup_adc_ports(RA0_ANALOG);
setup_adc(ADC_CLOCK_DIV_32);
setup_psp(PSP_DISABLED);
setup_spi(FALSE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
enable_interrupts(INT_AD);
enable_interrupts(global);
setDefalts();
resetCam();
loadReg(0);
loadData(128);
loadReg(1);
loadData(6);
loadReg(2);
loadData(1);
loadReg(3);
loadData(85);
loadReg(4);
loadData(1);
loadReg(5);
loadData(0);
loadReg(6);
loadData(0);
loadReg(7);
loadData(33);
startCam();
printf("lets hope this works");
while(0==input(READ)); //ENDLESS LOUP TILL READ GOES HIGH
}//END OF ENDLESS LOOP
}//END OF MAIN
Haplo
Joined: 06 Sep 2003 Posts: 659 Location: Sydney, Australia
Posted: Sat Sep 25, 2004 3:20 am |
As I told you before, you CAN NOT step through printf. Set a breakpoint on the statement right after the printf and run the code. You'll see it will run just fine. If you try to step through it, the timing of the internal UART gets messed up and nothing/junk will be transmitted. In the case of nothing going out of the port, it will appear that the simulator is stuck. |
No I can not get to the wile loop after printf w breakpoint. |
Posted: Sat Sep 25, 2004 11:52 pm |
No I can not get to the wile loop after printf with a breakpoint. |
Mistress Z Guest
Teague would never do such a t |
Posted: Sat Mar 26, 2005 12:50 pm |
As Chrissy skipped ahead of me I counted out the bills in my hand Windriver Ghost. Chrissy had rolled over onto her stomach seemed on the verge of nodding off 3d Pacman. Long fake eyelashes were added and a heavy coat of mascarra applied, followed with the eyeliner Ossp Str. I began to nibble at her earlobe as I withdrew and sunk in again I18nhtml. Her little girl cotton [spam] were atop the heap I picked everything up and headed for the bathroom Rockrun. |
bluetooth
Re: No I can not get to the wile loop after printf w breakpo |
Posted: Sat Mar 26, 2005 1:06 pm |
Anonymous wrote: | No I can not get to the wile loop after printf with a breakpoint. |
To get around this problem, just put a "dummy" instruction after the printf, like maybe
i=0;
you can set your breakpoint there. |
