Sine Function....
tedlarson
Sine Function....
PostPosted: Thu Sep 23, 2004 3:50 pm     Reply with quote
Anyone know where I can find some 'C' source for a sine function that uses a larger lookup table for more accurate results? I am using the sin function built-into the CCS C compiler, and the results get pretty inaccurate when dealing with very small numbers, because the interpolation is using such a small number of starting values.
Thanks,
- Ted
Haplo
PostPosted: Thu Sep 23, 2004 5:40 pm     Reply with quote
You can easily generate the look-up table with the desired size on a PC, and then use it in your PIC.
These sites may be helpful:
http://www.brouhaha.com/~eric/pic/sine.html
http://www.audiomulch.com/~rossb/code/sinusoids/
Mark
PostPosted: Thu Sep 23, 2004 8:09 pm     Reply with quote
Doesn't CCS use the code in math.h?
C-H Wu
Re: Sine Function....
PostPosted: Thu Sep 23, 2004 10:55 pm     Reply with quote
tedlarson wrote:
... I am using the sin function built-into the CCS C compiler, and the results get pretty inaccurate when dealing with very small numbers, ...
Thanks,
- Ted
I noticed this problem early this year and did some modification, try my code ...
float sin(float x)
   return cos(x - PI_DIV_BY_TWO);
float cos(float x)
   float p[7] = { -1.2337025e+0, 2.53680e-1, -2.08780e-2, 9.10e-4, // cos()
                  -1.6666700e-1, 8.33220e-3, -1.94400e-4  };       // sin()
   float y, x2, c = 1.0;            int8  quad, i = 0, n = 4;
   if (x<0) x = -x;                 // absolute value of input
   x2   = x / PI_DIV_BY_TWO;        // normalization
   quad = (int8)x2;                 // quadrant
   x    = x2 - quad;                // fractional part of input
   quad = quad % 4;                 // quadrant (0 to 3)
   if (quad==1)   x = 1.0 - x;
   if (quad==3)   x = x - 1.0;
   if (x>0.5)     // sin_n(x)
      i=4; n=7;   c = x = PI_DIV_BY_TWO - x * PI_DIV_BY_TWO;
   y  = c;
   x2 = x * x;
   while (i<n)
      c = c * x2;
      y = y + c * p[i];    ++i;
   if (quad==2 || quad==1) y= -y;   return (y);
Best wishes
C-H Wu
PostPosted: Thu Sep 23, 2004 11:50 pm     Reply with quote
oops, to get some more code size and code speed optimization ...
float const p_sc[7] = { -1.2337025e+0, 2.53680e-1, -2.08780e-2, 9.10e-4, // cos()
float cos(float x)
   while (i<n)
      y = y + c * p_sc[i];    ++i;
C-H Wu
fast and accurate sine-cosine function
PostPosted: Sat Sep 25, 2004 1:08 am     Reply with quote
to make it even faster, 640 usec compared with CCS's 1070 usec using math.h
#define  PI_DIV_BY_TWO  1.570796327
#define  TWO_DIV_BY_PI (1.0/PI_DIV_BY_TWO)
// x2   = x / PI_DIV_BY_TWO;        // normalization
   x2   = x * TWO_DIV_BY_PI;        // save 200 usec for 18F
then I ran into the bug in PCH 3.203 ~ 3.211 making x * (1/x) equals 0.5, and sin(0) returns 0.707 ! Shocked
see http://www.ccsinfo.com/forum/viewtopic.php?t=20561
This bug is fixed in PCH 3.212, and now sin(0) returns 0.0 with this routine instead of 2.3e-5 with CCS's math.h. Very Happy
code size and RAM usage is also slightly smaller than the cos() of CCS. Very Happy
languer
Another site with good information
PostPosted: Sun Sep 26, 2004 2:41 am     Reply with quote
This thread also has some good information.
http://www.picbasic.co.uk/forum/showthread.php?s=&threadid=718
mcafzap
PostPosted: Sun Sep 26, 2004 10:16 am     Reply with quote
Try this too - he gives algorithms for various accuracies:
http://www.ganssle.com/articles/atrig.htm
