Strange finding (CCS rev 3.186) |
Posted: Tue Sep 21, 2004 1:55 pm |
Recently, I ran into a series strange problems with 18F8620 & CCS
When I burn a "good" program my designs, some of them will not run.
If I give pic a reset signal, it will run fine.
so the problem seems to be in the reset, but I confirm good clock/reset/voltage, etc -- I contacted microchip and show them my design and fuse map, and they didn't find anything wrong.
I can reprogram the pic many times and it still will not come out of reset
Yet, if I add a few dummy lines in my source, as simple as "i=i-1; i=i+1':, recompile and program pic again, they will all work fine!
![Sad](images/smiles/icon_sad.gif) |
dyeatman
Posted: Tue Sep 21, 2004 2:09 pm |
What speed are you running? Are you using 4xPLL? |
Posted: Wed Sep 22, 2004 9:20 am |
29.xx MHZ
Because this problem only happens to some but not all systems, and the program is rather big, and any change will take care the problem, it will not be easy to come up with a small test program to demonstrate
asmallri
Posted: Wed Sep 22, 2004 9:24 am |
It may be an interrupt related software problem |
Mark
Posted: Wed Sep 22, 2004 5:33 pm |
Check the errata on the PIC. Some of the bigger 18's had problems at over 4MHz. Does the date code start with 03 or 04? |
