GPRS modem gr47
bercam4
GPRS modem gr47
PostPosted: Mon Sep 13, 2004 5:48 am     Reply with quote
anyone has worked with it?
bercam4
PostPosted: Mon Sep 13, 2004 5:50 am     Reply with quote
Exactly is a GSM/GPRS modem from SonyEricsson and it is programmable by AT Comands
PostPosted: Mon Sep 13, 2004 7:26 am     Reply with quote
Seems like a nice module to me. We have looked into using it but decided on using the Wavecom Integra M2106B instead because with the Wavecom module you can order an integrated TCP/IP stack without additional costs and the Wavecom is a bit faster in the upload (4+2 device instead of 4+1).
bercam4
programming
PostPosted: Thu Sep 16, 2004 2:35 am     Reply with quote
I'm using GR47 device, wich contains a TCP/IP stack.
Are you using to send data by GPRS to IP address?
Do you know another forum to learn more about AT comands in GPRS modems?
Regards
PostPosted: Thu Sep 16, 2004 2:45 am     Reply with quote
Yes. My application is something like a GPRS-enabled datalogger, we receive data over RS-232 and store this in a MMC-flash card. Depending on the customer requirements collected data reports are send every minute to once a day to a pre-defined ip-address.
No, I only used the Wavecom manuals and that was sufficient for me.
bercam4
GPRS
PostPosted: Fri Sep 17, 2004 2:47 am     Reply with quote
Did you had any problem with your IP security ?
What software are you using to read data in host from IP? Are you using sockects to implement this?
Thanks you for your help.
PostPosted: Fri Sep 17, 2004 3:12 am     Reply with quote
This question is too general to give a more specific answer to. But, no, not yet any problems with IP security. At the host we have a firewall running only allowing the pre-defined port numbers and we can make it even tighther by only allowing the ip-range of our GPRS provider.
The protocol is our own development so we had to develop our own host as well. An advantage of this is that security is much easier as well, as no hacker will know the protocol (at least in the beginning of our project).
Yes. Sorry, I don't understand why you ask this question. Sockets instead of what other solution you are thinking of?[/quote]
bercam4
GPRS modem gr47
PostPosted: Mon Sep 20, 2004 3:16 am     Reply with quote
Your explanations are very appreciated for me.
I'm making the PCB and learning about AT comands in order to program the module with PIC18.
I'm working in telemetry project and I'm thinking about two posiblities,
1.- Using SMS with Emitter and receiver.
2.- If amount data is bigger using GPRS to IP address.
I'm hardware engineer and I have experience only with Visual Basic-C as PC programs. I know about sockect to connect to another IP.
