Checking a byte for odd parity
Snowblind
PostPosted: Fri Nov 23, 2001 3:40 am     Reply with quote
Im interfacing a 16c84 with a AT keyboard I have it receiving the keyboard scan code and parity bit fine.
I now want to check the parity bit for correctness. I'm currently iqnoring it
The way I understand odd parity is counts all the one in a byte and makes the parity a 0 or 1 to make the byte and the parity bit have a odd number of ones
I also plan on sending keyboard scan codes to the computer.
So Im hoping one of you guys that is better at software than I can show me how to check and generate a parity bit from a byte
___________________________
Original Post ID: 1299
Tomi
Re: Checking a byte for odd parity
PostPosted: Fri Nov 23, 2001 1:02 pm     Reply with quote
Try this:
char GetParity(char be)
be ^= be >> 4;
be ^= be >> 2;
be ^= be >> 1;
be &= 0x01;
return (be);
Output: 0->Even, 1->Odd
:=Im interfacing a 16c84 with a AT keyboard I have it receiving the keyboard scan code and parity bit fine.
:=I now want to check the parity bit for correctness. I'm currently iqnoring it
:=The way I understand odd parity is counts all the one in a byte and makes the parity a 0 or 1 to make the byte and the parity bit have a odd number of ones
:=I also plan on sending keyboard scan codes to the computer.
:=So Im hoping one of you guys that is better at software than I can show me how to check and generate a parity bit from a byte
Original Post ID: 1302
Snowblind
PostPosted: Fri Nov 23, 2001 3:24 pm     Reply with quote
Thank you,
Works great I had to add a line to get the output i wanted
after this line be &= 0x01; I put a be ^= 0x01;
You me past the bit shifting i have problems getting that down
:=Try this:
:=char GetParity(char be)
:=be ^= be >> 4;
:=be ^= be >> 2;
:=be ^= be >> 1;
:=be &= 0x01;
:=return (be);
:=Output: 0->Even, 1->Odd
:=:=Im interfacing a 16c84 with a AT keyboard I have it receiving the keyboard scan code and parity bit fine.
:=:=I now want to check the parity bit for correctness. I'm currently iqnoring it
:=:=The way I understand odd parity is counts all the one in a byte and makes the parity a 0 or 1 to make the byte and the parity bit have a odd number of ones
:=:=I also plan on sending keyboard scan codes to the computer.
:=:=So Im hoping one of you guys that is better at software than I can show me how to check and generate a parity bit from a byte
Original Post ID: 1308
