Markus
Kinda "pointer to function" question! |
Posted: Tue Sep 14, 2004 7:50 am |
Heyhey!
This code works:
#device *=16
byte Read(myData index) {
return *index;
typedef byte *myData;
typedef byte (*readFunc)(myData index);
readFunc do_Read;
do_Read = Read;
But this one doesn't:
#device *=16
return *index;
typedef int16 (*readFunc)(myData index);
readFunc do_Read;
do_Read = Read; // (*)
It returns with:
CCS 3.184 wrote: |
*** Error 118 "...\test.c" Line (*): Invalid type conversion
What am I missing?
Markus |
Mark
Posted: Tue Sep 14, 2004 10:27 am |
The function is declared with a return value of a byte and not int16 |
Markus
Posted: Tue Sep 14, 2004 11:35 am |
Mark, you're right. I made this mistake while writing my first post. It _is_ defined as int16 in the project, but that doesn't work (see above)...
Markus |
Mark
Posted: Tue Sep 14, 2004 11:50 am |
Not sure what you are trying to do but this works just fine:
#if defined(__PCM__)
#include <16f877.h>
#device *=16
#elif defined(__PCH__)
#include <18f452.h>
#device *=16
int16 Read(myData index)
return *index;
readFunc do_Read;
mydata test;
byte input = 123;
int16 result;
test = &input;
do_Read = Read;
result = (*do_Read)(test);
Tom-H-PIC
Joined: 08 Sep 2003 Posts: 105 Location: New Castle, DE
pointers to function ? |
Posted: Tue Sep 14, 2004 1:20 pm |
Ok the question do pointers work with function or not?
Maybe I have not totally thought this through but what is the point of the pointer to a function thing?
If a person writes a function and uses it in code the compiler uses a goto in the list file to jump to the function. To me this would be the same as a pointer to the function.
Or are we saying that we would be able to use pointers to a function like a pointer to fprintf and only have one fprintf in the total code.
Thanks guys it will help if you can help clear up my thinking on this. |
Mark
Posted: Tue Sep 14, 2004 1:30 pm |
With a pointer to a function, you can dynamically assign a function call to a variable and then call it. It is great for doing menus and command parsers. You only need one handler and typically get the function addresses from a constant look up table. Here is another use. Let say you have a device that has 2 ports. Lets say you want to be able to select which port the data goes out at runtime. Well you just create 2 functions. One for each port. Now all your output uses the function pointer. Simply set the pointer equal to the function that you want to use (maybe something like
if (debug)
pFunc = DebugOutput;
pFunc = NormalOutput;
) does it make sense yet?
More reading: http://www.ccsinfo.com/forum/viewtopic.php?t=20416 |
Trampas
Posted: Tue Sep 14, 2004 7:03 pm |
Another example of using pointer to function is in state machines. Do you guys remeber Melly and Moore (spelling?) state machines? Well you can set up a table of states and what function to call when you are in that state and/or what function to call when you change states.
Trampas |
Bilk Guest
pointers to functions |
Posted: Thu Sep 16, 2004 1:21 pm |
Beware: I have found that pointers to functions work -- but there seems to be a problem if an interrupt occurs exactly when the pointer to function call is being pushed.
The ISR_() destroys the stack push and the program continues neatly. The desired (*ptr_funct)() is then never called.
Workaround, disable interrupts immediately prior to making (*ptr_funct)(); call and renable as first item in called functions.
Compiler version 3.208 - PIC18f452 |
