		| Author | Message |
		| coconico
				| search string in string |
				|  Posted: Tue Sep 07, 2004 6:22 am |   |
				|             Has any one a function that it search a string in an other string?
 Thank you for helpping!
		| Mark
				|  Posted: Tue Sep 07, 2004 7:09 am |   |
				| Well how about the standard C function of strstr()? |  |
		| Haplo
				|  Posted: Tue Sep 07, 2004 11:15 pm |   |
				| As Mark pointed out, there is a standard C fucntion for this purpose called strstr(). In CCS, the code for strstr() is in the file STRING.H located in the \Drivers directory. Open it up and take a look at the source code. You can see:
  	  | Quote: |  	  | /* standard template:
 char *strstr(const char *s1, const char *s2);
 Locates first occurence of character sequence s2 in s1;
 returns 0 if s2 is empty string
 Uncomment #define FASTER_BUT_MORE_ROM at the top of the
 file to use the faster algorithm */
 Defining  FASTER_BUT_MORE_ROM is indeed much faster especially if you need to work on big strings, but it results in a bigger code.
 However, I remember having problems with the CCS strstr and writing my own. Still, the CCS code is a good starting point.
		| coconico
				|  Posted: Wed Sep 08, 2004 12:58 am |   |
				| Thank you very much. I don't saw this function.
 Thank you for your help.
